It is currently Sat Jan 20, 2018 10:18 am
 Post subject: carb on a GTi head.
PostPosted: Thu Dec 05, 2002 1:03 pm
How to carb a GTi head on a 1.6 sedan??<br>I got the GTi head but wan't to keep my original carb. <p></p><i></i>
 Post subject: Re: carb on a GTi head.
PostPosted: Fri Dec 06, 2002 11:29 am
banned
BIG UP TO MY WHEELSJAMAICA COMRAD<br>you can do it, but i would recomend a weber, single maybe or double if you can get it, if you are stuck with your oem carb you will have to build an 'adapter plate' for it to bolt up to the head, and you will need to block the injecter holes<br><br>cheers <p></p><i></i>
PostPosted: Fri Dec 06, 2002 12:40 pm
Thanks for the info.<br><br>First i wanna start with my original carb.<br>see if everything works right and then maybe a weber or bike carbs.<br><br>I totaly forgot about the injector holes, Whats the best way to block them??<br><br>Did somebody do this before?? I would like to see some pic's. <p></p><i></i>
PostPosted: Mon Dec 16, 2002 11:45 pm
banned
i know several people that have double or single carbs on them, not sure how they blocked up the holes, ill ask, cant get pictures thoug<!--EZCODE EMOTICON START :( --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/frown.gif ALT=":("><!--EZCODE EMOTICON END--> h <p></p><i></i>
PostPosted: Tue Dec 17, 2002 11:47 am
I think I put in the original injectors with rail. <p></p><i></i>
