It is currently Thu Oct 19, 2017 6:27 pm
 Post subject: Carbs on a 8 valves ?
PostPosted: Mon Jan 06, 2003 3:27 pm
i was wondering if i could carb my 1.3 sohc???<br>i saw some webbers for the 1.3 samurai ,, could they fit ?? (20% gain) ??? could i put a samy stock carb on my car ??? do i need headers ? <br><br>if anyone did such a convertion ,, please help me !<br> <p></p><i></i>
 Post subject: Re: Carbs on a 8 valves
PostPosted: Tue Mar 18, 2003 5:07 pm
In short yes you can change to carbie. I would also suggest you pipe some cold air to it , put in a K&N filter and free up the exhaust but take the advise of sombody that has done all that, don't then be coned into changing to a larger Carbie! You simply don't need to ! It may sound a bit throutier but at the end of the day all you will do is cost yourself power and money. The cheapest and most effective way of getting some extra neddies out of your rice grinder is rejet your standard carbie and then do the other stuff I mentioned. I have seen a dyno printout of a mate of mine who has pulled 70Kw at the wheels with a rejetted stock carbie. Admittedly there was a fair bit of work done to the head but it was still 1298cc and in road trim.<br><br>Good luck <br>Jed<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <p></p><i></i>
