It is currently Sun Jan 21, 2018 12:38 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2  Next
PostPosted: Thu Jan 09, 2003 7:06 pm
Senior Swift Guru
This thread will be for all of those who have information to share in regards to carb conversions on their GTi. If it is useless information I will delete the post and it can be started in a different thread. Pictures, advice, tips and information will all be very useful and left on.<br><br><br>-Kyle Jones<br> TeamSwift Administrator <p></p><i></i>
PostPosted: Fri Jan 10, 2003 8:35 pm
Anyone have pictures of a stock 1.3 carb on a 1.3 16V engine?<br>Thanks!<br>Vince. <p></p><i></i>
PostPosted: Fri Feb 14, 2003 7:32 pm
I'm currently working on a replacement manifold that will accept Mikuni style motorcycle carbs and a DIS (distributorless ignition) system that will replace the stock ECU controlled distributor. The stock distributor dosn't have any means for mechanicla advance and the DIS will advance the timing based on RPM. I expect these to be ready by late spring or early summer. Also in the works is a GTi to Samurai distributor adapter that will allow you to run a mechanically advanced Samurai distributor (or for you GTi swap Samurai guys it will give you adiquate firewall clearance to swap in the motor without having to modify the firewall)<br><br>Thanks<br>Adam (Teamswift Webstore Webdaddy) <p></p><i></i>
 Post subject: twin 40 DCOE's
PostPosted: Sun Feb 16, 2003 1:37 pm
I've just had twin 40 DCOE's fitted to my UK R/H drive car. The main problem withthis conversion on a R/H drive is the placement of the stock brake master cylinder.<br>If you want a pic of the installation send me an email.<br><br> <p></p><i></i>
 Post subject: Re: twin 40 DCOE's
PostPosted: Tue Jun 24, 2003 3:43 pm
Senior Member
Big Bear..use a Mk1 distributor. It can be modified mechanically to give you any curve you want. Mine has 14 degrees base timing and a total of 20 degrees avance to give me 34 degrees at 5000rpm.<br><br>As for the Samurai-GTi engine distributor adaptor...Suzisport here in Oz already has done a 90 degree adaptor for that application. <p></p><i></i>
 Post subject: pictures
PostPosted: Thu Jul 17, 2003 10:27 pm
Hi,<br><br>I too drive on the R/H and I'm in Malaysia.<br><br>Would you mind sendin the pictures over.<br><br>Thanks<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <p></p><i></i>
 Post subject: Re: pictures
PostPosted: Mon Jul 21, 2003 9:08 pm
pics from poruki, a 3cylinder carb conversion into a rear engined porsche. take note of the trick optical/direct ignition system & adapters<br><!--EZCODE IMAGE START--><img src="http://www.wizardly.org/swifts/julymeet03/images/july_swift_meet%20067.jpg" style="border:0;"/><!--EZCODE IMAGE END--><br><!--EZCODE IMAGE START--><img src="http://www.wizardly.org/swifts/julymeet03/images/july_swift_meet%20065.jpg" style="border:0;"/><!--EZCODE IMAGE END--><br><!--EZCODE IMAGE START--><img src="http://www.wizardly.org/swifts/julymeet03/images/july_swift_meet%20061.jpg" style="border:0;"/><!--EZCODE IMAGE END--><br>more pictures <!--EZCODE LINK START--><a href="http://www.wizardly.org/swifts/julymeet03/index.html" target="top">are here</a><!--EZCODE LINK END--> <p></p><i></i>
PostPosted: Thu Aug 28, 2003 6:37 pm
Hi Kyle, My name is Steve, and we (Mike and I) are sammi people. We are trying to put a 1.3dohc head on a sammi block with a weber. Is there anything out there available to do this with? Will a stock sammi carb intake manifold bolt up to a dohc head? We haven't bought the head yet, but are close. Also wondering if multipurpose cams are available for the dohc head.........Thanks for pointing us in the right direction.....we have already built sammi's that really growl with big webers..........Steve <p></p><i></i>
PostPosted: Thu Aug 28, 2003 9:47 pm
i'll try to post some pictures tomorrow, wayne sent me some updated pics of his new cultus/gti 1.3 dohc w/ a gorgeous carb setup .. i assume he's made all the adapters himself .. & poruki does some sweet machining ! =)<br>the porsche should definately have a bit more performance soon =) <p></p><i></i>
PostPosted: Sat Aug 30, 2003 7:58 pm
Hey Nitr0, Looking forward to those pics and info! What about a right angle distributor adaptor? Thanks.....Steve<!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Sun Aug 31, 2003 3:36 am
wayne sent me these pics a few days ago .. i've been slacking on the upload .. =P<br>damn he does some nice work !!<br><!--EZCODE IMAGE START--><img src="http://www.wizardly.org/swifts/poruki/Mik1.jpg" style="border:0;"/><!--EZCODE IMAGE END--><br><!--EZCODE IMAGE START--><img src="http://www.wizardly.org/swifts/poruki/Mik2.jpg" style="border:0;"/><!--EZCODE IMAGE END--><br><!--EZCODE IMAGE START--><img src="http://www.wizardly.org/swifts/poruki/Mik3.jpg" style="border:0;"/><!--EZCODE IMAGE END--><br><!--EZCODE IMAGE START--><img src="http://www.wizardly.org/swifts/poruki/Mik4.jpg" style="border:0;"/><!--EZCODE IMAGE END--> <p></p><i></i>
PostPosted: Sun Aug 31, 2003 11:31 am
Thanks for the pics, n1tr0. Real nice work on display. Sure would like to see someone figure out how to put weber DG's on it. Mabe Wayne could share the love on how he built his intake...............Steve<!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Mon Sep 01, 2003 8:28 am
you can see some pics of my engine with a dual weber 45mm dcoe setup at <!--EZCODE AUTOLINK START--><a href="http://photos.yahoo.com/bdgracia">photos.yahoo.com/bdgracia</a><!--EZCODE AUTOLINK END--> Go to the swift gti folder.<br><br>Bolivar <p></p><i></i>
PostPosted: Tue Sep 02, 2003 6:58 pm
Hi Bolivar, Thank you for the pics of your Swift. Wow! Looks hot. Where did you get your intake manifold? Or did you make it yourself? I would like to hear how you did this, Thanks, Steve<!--EZCODE EMOTICON START :p --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/tongue.gif ALT=":p"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Wed Sep 03, 2003 7:14 am
Steve,<br><br>The first manifold was made here in Panama with cast iron parts. I still have this manifold if you wan it.<br><br>I currently have a aluminium manifold made by a company in belgium call chadil.<br><br>Bolivar <p></p><i></i>
PostPosted: Wed Sep 03, 2003 8:42 pm
Hi Bolivar,<br>How much do you need for your old manifold? I am definitely interested. By the way, how fast is your Gti? Have you determined the horsepower? What kind of distributor setup are you using? I couldn't see a distributor on your Swift pictures. Thanks!<br>Steve <p></p><i></i>
PostPosted: Thu Sep 04, 2003 1:44 pm
Steve,<br><br>The cost of the manifold was like $250 USD. Make me an offer.<br><br>My engine does not have a distributor, I have an electromotive HPX ignition that works with a crank trigger wheel.<br><br>We don't have a dyno in Panama, but power should be in the 140-180HP.<br><br>Bolivar <p></p><i></i>
PostPosted: Fri Sep 05, 2003 5:05 pm
Hi Bolivar, <br>Could we talk off-line from teamswift? My email is senelect@ris.net Perhaps we could exchange phone numbers there and talk in-depth about engines. It seems you have been where we want to go. We live in Colorado, which is on Mountain Time Zone. Thanks! Steve and Mike <p></p><i></i>
PostPosted: Sat Sep 06, 2003 12:13 am
hey i'd love it if you could keep this on the forum .. there's some great info going back 'n' forth here.<br>=) <p></p><i></i>
PostPosted: Mon Sep 08, 2003 9:42 am
Steve,<br><br>My email is bdgracia@yahoo.com.<br><br>Bolivar <p></p><i></i>
PostPosted: Tue Sep 09, 2003 6:58 pm
Hi n1tr0, I'll keep my discussion going on the forum except for financial transactions. Agreed,-lots of good info coming out here. Was talking to a guy in Ohio who I bought my gti head from, and there is one member of their gti group who is putting out.......450 horsepower! Sounds like he basically has incorporated some F1 technology into his Swift. His IS fuel injected, but he has reached the absolute top limit of fi technology for the zuk. He is now switching over to Webers.........will keep forum posted as more info is forthcoming. Bolivar, I will get back to you in another day or two,-working way too many hours this week!.....Steve <p></p><i></i>
 Post subject: Carbs
PostPosted: Wed Oct 01, 2003 10:47 am
I am rebuilding another engine with a shaved head, port & polish, and some nice cams, I will definatly get this dynoed to see the horsepower gains.
PostPosted: Mon Mar 15, 2004 6:16 pm
Which Bike carbs are recommended for this convertion???
Is it best to get the carbs from a bike with high cc ratings like a Suzuki GSXR1100???
Do i have to get bigger jets even after I get them???.......
Happiness is only a little boost away
 Post subject: .....
PostPosted: Mon Mar 15, 2004 6:46 pm
Senior Member
Go with 38 or 40mm carbs....some of the smaller ones can have trouble flowing enough fuel on a modified GTi engine. Or maybe that should read GTc engine...
If you can afford it, the aftermarket carbs are more easily tuned although CV carbs can still be tuned to run quite successfully. Jet changes are required, yes.
 Post subject: Re: .....
PostPosted: Tue Mar 16, 2004 5:00 pm
Thanks but I have one more question!!
I’ve been searching all over for bike carb’s and found allot but one problem the largest i can find are 36mm even on eBay
So my Question is do you know which Brand Bike carb is used for this conversion??
