It is currently Sun Feb 25, 2018 11:22 am
PostPosted: Thu Feb 13, 2003 1:46 pm
is it possible to run a turbo with dcoe carbs???<!--EZCODE EMOTICON START :hat --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Thu Feb 13, 2003 3:23 pm
yes it is. A lot of people do this with the toyota 3T engine in puerto rico.<br><br>Bolivar <p></p><i></i>
 Post subject: how??
PostPosted: Fri Apr 04, 2003 2:57 pm
do you have to change something on the carbs or just put the turbo on the carbs? <p></p><i></i>
 Post subject: Turbo
PostPosted: Fri Apr 18, 2003 6:49 am
I was thinking of putting a 3Cyl turbo on my stock G13B with 4 bike carbs, anyone can tell me what do I need to run this?<br>I have no more computer.<br>Thanks!<br>Vince. <p></p><i></i>
 Post subject: Re: Turbo
PostPosted: Sat Apr 26, 2003 12:30 pm
the problem with running a turbo with carbs is that you have the tune the Air fuel ratio to your maximum boost. This means anything under max boost you'll be running major rich with lots of black smoke<br><br>Adam<br><br>Teamswift Webstore Webdaddy <p></p><i></i>
 Post subject: carbs & turbo
PostPosted: Fri May 09, 2003 4:48 am
bigbearzuke, so how is this problem solved on a renault 5 GT turbo? Or other turbocharged/supercharged & carbed cars? <p></p><i></i>
 Post subject: Re: carbs & turbo
PostPosted: Mon May 12, 2003 12:41 pm
great big expensive development teams & in-house dynos... <!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Sun May 25, 2003 11:13 am
The mad quebecer
The mad quebecer
They have a pressure sensitive valve that open an extra fuel line acordingly to manifold air pressure. This valve can be tuned for richer/poorer setup. Depending of the car/model, the valve vas either intagretad to the carb or was a remote unit. <p>Jardamuth<br><br></p><i></i>
