It is currently Fri Oct 20, 2017 3:59 am
PostPosted: Wed Feb 19, 2003 9:29 pm
What's up folks,I've got a lot of pics of my car,so if any one wants to see them just mail at romery@sirbet.com and I'll send you few of them so you can see how it fits and how the NOS wet system is installed and everything.<br><br>Allright see you guys mail me...........<br>lulyrast<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br><br>ps:if any one knows how to post the pics on the board please let me know <p></p><i>Edited by: <A HREF=http://pub83.ezboard.com/bteamswift.showUserPublicProfile?gid=lulyrast>lulyrast</A> at: 2/19/03 8:32:48 pm<br></i>
PostPosted: Thu Feb 20, 2003 4:55 pm
pictures are <!--EZCODE LINK START--><a href="http://www.wizardly.org/swifts/Romery/index.html" target="top">online here</a><!--EZCODE LINK END--> =) <p></p><i></i>
PostPosted: Fri Feb 28, 2003 8:01 pm
Those are some nice pics!<br><br>a couple of questions:<br>do you have anything other than those rubber hoses going from the carbs to engine holding the carbs in place?<br><br>Which carbs are you using?<br>Is the spacing between the carbs the same as spacing between cylinders already, or did you have to modify?<br><br>how big of a nos bottle is that 10lb? I like where it's mounted I mounted mine in the trunk because I'm afraid of cops.<br><br>I definately like your setup! <p></p><i></i>
PostPosted: Sat Mar 01, 2003 6:40 pm
They look like Mikuni flatside carbs to me. There the better bike carbs to get but you can run regular "round" dsides. I'm working on a mikuni intake manifold that should be ready by late spring<br><br>Adam <p></p><i></i>
PostPosted: Wed Mar 12, 2003 6:38 pm
No I only have those rubber hoses holding the carbs to the intake manifold<br><br>I'm using 40mm mikuni bike carbs(not flatside)<br><br>My NOS botle is a 10lb one <p></p><i></i>
PostPosted: Wed Mar 12, 2003 6:42 pm
I'm running this coming friday 14 of march at our street legal race,and I'm going with 70 hp.hope I reach a 13 sec you'll hear about it coming weekend or you guys can chek it on <br><!--EZCODE AUTOLINK START--><a href="http://www.curstreet.com/">www.curstreet.com/</a><!--EZCODE AUTOLINK END--><br>on this page you can always find everything related with races,cars and many other things about curacao have a look at this page guys <p></p><i>Edited by: <A HREF=http://pub83.ezboard.com/bteamswift.showUserPublicProfile?gid=lulyrast>lulyrast</A> at: 3/12/03 5:46:38 pm<br></i>
 Post subject: 1/4 mile time
PostPosted: Fri May 30, 2003 3:50 pm
Hey, amazing motor<br>What´s your 1/4 mile time ?<br>With this mods can you use the car for daily driving or race only ?<br><br>Jason <p></p><i></i>
 Post subject: Re: 1/4 mile time
PostPosted: Mon Jun 02, 2003 3:24 pm
Well as I said before I don't know my time yet that's because I had many problems at the track..but I speculate around 13 sec high with my 70 hp...It is my daily driven car my friend..you want to have some fun...go for it..it gives you a lot of power at the wheels by only putting those bike carbs..or any other side drafts carbs...(without NOS)rans a 15:40 sec 1/4 mile<br><br>MODS:40mm bike carbs<br> 6al MSD/wires 8.5mm<br> NOS instalation<br><br><br>have fun..take care<br>Lulyras <p></p><i></i>
PostPosted: Wed Jun 04, 2003 11:02 am
What kind of fuel pump are You using and what type (from what bike) they are??<br>Also what is that red box naxt to cam gears??<br> <p></p><i></i>
PostPosted: Wed Jun 04, 2003 3:16 pm
Well those carbs are from the 93's gsx-r's <br>that red box is my 6-al MSD ignition box<br>I'm using a red HOLLEY fuelpump....but you can also use those electric fuelpumps from 4-7,5-9 psi...they are a lot cheaper than a holey and they work great!!<br><br><br>Take care,<br>Regards....<br>Lulyras <p></p><i></i>
 Post subject: question for you?
PostPosted: Wed Jun 04, 2003 4:24 pm
what did you do with the factory injectors holes that are in the cylinder head? hopefully you know what i am talking about? This is my only concern when putting on my carb set-up?<br><br>Also do you have any pics of the install process?<br><br>Any help would be greatly appreciated!!<br><br>Thank Chris <p></p><i></i>
 Post subject: carbs
PostPosted: Tue Jun 17, 2003 10:41 am
how is the fuel controlled on the carbs? with the injectours its the ecu so you have to wire it through there? <p></p><i></i>
 Post subject: Re: carbs
PostPosted: Tue Jun 24, 2003 3:40 pm
Senior Member
Fuel is controlled by jetting of the carbs and the fuel pressure that is set by the regulator. There is no wiring.<br><br>You also need an appropriate ignition system as the one in Mk2 on GTi's is controlled by the ECU. <p></p><i></i>
PostPosted: Tue Jun 24, 2003 11:48 pm
Why ignition system?? Stock mk1 won't work? I think that ecu should still be able to control spark, isn't it?? <p></p><i></i>
 Post subject: Carbs
PostPosted: Thu Jun 26, 2003 8:36 am
oh ok i get it now. thanx <p></p><i></i>
 Post subject: Re: Carbs
PostPosted: Mon Jun 30, 2003 2:23 pm
Hey Colin the Barbarian..you won't need any ECU if you <br>'re running a mk1..I don't even know where mine is now!!!<br>So if you wanna go running carbs what you will need is ...<br><br>1)fuelpump between 3-7psi is fine<br>2)bike carbs<br>3)FPR ...holley is a good one 4,5-9psi<br>4)intake manifold of course<br><br><br>You can run stock ignition and with or without your ECU ...<br><br>Regards<br>Lulyrast<br> <p></p><i></i>
 Post subject: carbs
PostPosted: Tue Jul 01, 2003 10:27 am
so you have to have an intake manifold made for it?<br><br>how is the mileage affected with carbs? <p></p><i></i>
