It is currently Tue Jan 16, 2018 11:09 am
PostPosted: Fri Feb 21, 2003 10:53 am
Alright folks,here are some of my pics <br>Hope you like them,any question don't hesitate to ask me or e-mail me at <!--EZCODE AUTOLINK START--><a href="http://www.romery@sirbet.com">www.romery@sirbet.com</a><!--EZCODE AUTOLINK END--><br><br>Take care,<br><!--EZCODE AUTOLINK START--><a href="http://www.wizardly.org/swifts/Romery/index.html">www.wizardly.org/swifts/R...index.html</a><!--EZCODE AUTOLINK END--> lulyrast<!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <p></p><i>Edited by: <A HREF=http://pub83.ezboard.com/bteamswift.showUserPublicProfile?gid=lulyrast>lulyrast</A> at: 2/21/03 10:12:50 am<br></i>
PostPosted: Thu Apr 22, 2004 6:57 am
that's awesome :razz: I got rebuilt engine from mk1 but I ainn't got ECU, so I wantt to do the same,
Got one question, how is the fuel economy ? is the car using much more fuel than on EPI ?
fuel is so expensive in Europe :x :x :x
 Post subject: .....
PostPosted: Fri Apr 23, 2004 9:42 pm
Senior Member
So cool to see you back on the boards! Glad you found your pics, too, or did you take some more?
PostPosted: Fri Apr 23, 2004 11:27 pm
Simply amazing car.
PostPosted: Sat Apr 24, 2004 3:50 pm
Well I've allready ordered Kawasaki Ninga 4x36,5 mm carbs :razz:
What do u think ? is it gonna be a good setup ?
 Post subject: .....
PostPosted: Sat Apr 24, 2004 10:14 pm
Senior Member
Someone I know of tried the 'smaller' sized bike carbs and found that, while they flowed enough air, they could not support enough fuel flow. Not sure exactly what bike carbs they were, though. Was a while ago I had that chat but I vaguely remember something about the fuel bowl size.
PostPosted: Tue Apr 27, 2004 5:06 pm
Swifterr: I currently have a set of 34.5 Kaw's on my setup, and I concur with Oz. Fuel barely keeps up with my 1.0 3cyl. I also had to custom jet them, and still was unhappy. With the 36.5's you might have better luck though.
Next up, R1's like the rest of the group! Installing this weekend if all goes to plan!
'90 Geo "Retro"- 3x Mikuni Carb 1.0
Custom ground performance Cam
Custom advanced timing cam gear
MSD 6al control, coil, wires.
2" exhaust from the hollow cat back
Short throw shift
front & rear strut bars
lowered 1.5"
PostPosted: Wed Apr 28, 2004 9:29 am
What needles and jets are you using ?
I have 34 mm Mikunis CV's on my 1.0 and have NO fuel
flow problem.
PostPosted: Wed Apr 28, 2004 1:16 pm
deam I hope so
My are from 1 litre engine bike, will they be able to keep up with fuel ? I was advised to go with 38-40 mm throttles but they were hard to find :cry:
I got my carbs today well looks like thay can be fitted
http://picasaweb.google.com/summitsvift
PostPosted: Wed Apr 28, 2004 8:13 pm
Poruki: Since the ones I have are a stock model. after trying VERY hard to find jets and came up with nothing, I had to drill them to 185.
said reason is one reason Im changing to the R1's, Iv ebeen able to find alot more jets and such for them, versus what I have now.
Short throw shift
lowered 1.5"
 Post subject: .....
PostPosted: Thu Apr 29, 2004 2:54 am
Senior Member
Ah, the guy who ran into fuel issues was running them on a G13B. Bike carbs when on a car will always require bigger jets.
 Post subject: Re: .....
PostPosted: Thu Apr 29, 2004 6:00 am
I want to use them on g13b too :?
 Post subject: .....
PostPosted: Thu Apr 29, 2004 6:07 am
Senior Member
Another carb option you may be able to source would be GSXR1100 carbs like lulyrast uses. I could not use them as they would have fouled on my brake master cylinder - my car is RHD.
