It is currently Thu Oct 19, 2017 10:50 pm
PostPosted: Tue Oct 30, 2007 10:50 pm
I guess sometimes I take some of the stuff I know for granted, forgetting that it could be helpful to others.
I use this everytime I convert to a carb, and use the stock EFI in tank pump. I love it! You can hardly hear the pump run. When the regulator is set at a carb friendly pressure, the needle and seat in the carb opens at a higher pressure than does the regulator. It even works all the way down to 2.5 psi that weber recommends for the DFAV that I'm currently using.
PostPosted: Wed Oct 31, 2007 9:27 pm
Just so you know - on the carbed Swifts there is no regulator - the return line is simply teed off of the supply line - it does use a lower pressure pump though.
