It is currently Sun Oct 22, 2017 1:44 pm
 Post subject: Which carb?
PostPosted: Sun Nov 04, 2007 11:12 am
Hi people,
Have a carb conversion planned for my G13B. Dunno whether to go for 40mm R1 Yamaha carbs OR 38mm Mikuni carbs.
Would there be any power difference between these two carb sets? I`m tempted to go for the Mikuni carbs because i have found a manifold that will be a direct bolt on. But the Yamaha carbs will require me to modify my intake manifold. Will i see a massive difference in power between the two because one is 40mm and the other is only 38mm?
Sam
2000 Suzuki Swift GTi (MK2 1991 Engine)
PostPosted: Sun Nov 04, 2007 1:51 pm
the r1 carbs are mikuni carbs they are just made for that bike
where can you get the 38`s from and which manifold fits them? how much are they?
how much is the manifold?
if they are as cheap as a second hand set of r1 carbs than go for them coz it would cost you alot to get a proper custom manifold made for the r1 set
there will be almost no difference between the 2 in my veiw, the bore size just means that the r1 carbs will get a slight more air in thats all
gary
Have a look, you know you want to!
Swift. http://m.flickr.com/#/photos/11473969@N02/
Evo. http://m.flickr.com/#/photos/100754123@N04/
