It is currently Fri Oct 20, 2017 7:41 am
PostPosted: Sun Nov 25, 2007 12:27 pm
http://cgi.ebay.com/ebaymotors/ws/eBayI ... Track=true
Thinking of buying that fuel pump for my 40mm twin mikunis. Is that too much pressure or would it be ok? Can i really run it without a pressure regulator as they state, or should i still use my fuel pressure regulator ?
Cheers,
Sam
2000 Suzuki Swift GTi (MK2 1991 Engine)
PostPosted: Sun Nov 25, 2007 7:05 pm
Bozo the crying clown
from personal experience DCOE's like no more than 3psi. usually between 2 and 3psi is best. i would always run a regulator when using webers.
Matt
Megasquirt Specialist.
www.mtmotorsport.ca
PostPosted: Sun Dec 16, 2007 12:46 pm
You will need low pressure and high volume. The best pump is the carter low presure unit.
Facet are not very good and this one is a copy.
cron
