It is currently Tue Oct 17, 2017 8:04 pm
 Post subject: Two throttle cables?
PostPosted: Fri Nov 30, 2007 11:24 am
My 1100cc mikuni carbs have two throttle cables. What gives??
:? SAM
2000 Suzuki Swift GTi (MK2 1991 Engine)
PostPosted: Fri Nov 30, 2007 1:27 pm
What are the on or off of? My Yamaha seca 2 600cc has two, one pulls the throttle open the other pulls it closed. I assume it is a failsafe in case the return spring fails you can still close the throttle. If you are referring to a car it could either be for cruise control or an automatic transmission kickdown linkage.
93 Metro G10 MT
Removed TB Bridge, Advanced Timing, Removed Air box, Soon to be full length header, and advanced cam gear
PostPosted: Mon Dec 17, 2007 3:21 pm
Could one be the choke cable ???
Flat To The Mat
PostPosted: Thu Jan 31, 2008 5:54 pm
they are return cables for the throttle grip return
 Post subject: Re: Two throttle cables?
PostPosted: Sun Mar 23, 2008 5:42 am
My R1 Carbs has one for throttle and one for the choke!
Flat To The Mat
