It is currently Sun Jan 21, 2018 7:45 pm
PostPosted: Sat Dec 22, 2007 3:21 am
I found out that the two centre inlets on the Mikuni Side Draft carbs are slightly further apart than the standard Suzuki Swift GTi manifold, the gap where the throttle linkage goes. So you cant get all four carb inlets to have a direct straight path to the manifold venturi's. When i cut the inlet manifold in half there was actually a gap between the two halfs after fastening the silicone hoses up. Unless this is because i`m using a Suzuki RD inlet manifold , maybe it isn`t as wide as the standard GTi manifold?
2000 Suzuki Swift GTi (MK2 1991 Engine)
