It is currently Tue Oct 17, 2017 4:23 pm
PostPosted: Wed Dec 26, 2007 10:16 am
Mikuni throttle cable wont fit pedal end of GTi(e.g. there is nothing to hook on the foot pedal. + GTi throttle cable.. butterfly end is too big to fit the Mikuni. What do you guys and gals do about this ? Have i got to get a special throttle cable or is there some sort of modification?
Sam
2000 Suzuki Swift GTi (MK2 1991 Engine)
PostPosted: Wed Dec 26, 2007 2:52 pm
Senior Member
Drill the hole on the mikunis to accept the cable end off the gti...
calling all Homers, calling all Homers.... Doooooh
PostPosted: Wed Dec 26, 2007 4:26 pm
I got my cable modified, cost me $20 to get it shortened with the correct end crushed on to fit my cbr quads by a marine shop, there wasn't any way to drill mine out and I needed the outer housing much shorter anyway.
Have a ring around marine shops or brake shops in your area if you can't drill out the hole on your mikuni's.
PostPosted: Wed Dec 26, 2007 6:14 pm
There isnt enough material to drill the hole to the size required. The Mikuni throttle cable butterfly end is like 3 times smaller than the GTi one.
PostPosted: Wed Dec 26, 2007 8:36 pm
yep same with my CBR itbs, you will have to find somebody that makes and modifies cables, if you really get stuck then I get it done for you but postage will be more than the cost of the cable.
