It is currently Sat Feb 17, 2018 8:20 pm
PostPosted: Wed Jan 09, 2008 11:15 pm
When running bike carbs or TB's with integeal injectors what do you do with the existing injector holes in the block? Tks Russ
PostPosted: Thu Jan 10, 2008 12:12 am
Use the injectors in the head and block off the ones on the throttle bodies.
PostPosted: Thu Jan 10, 2008 7:28 am
But what if they were carbs????
PostPosted: Thu Jan 10, 2008 7:30 am
Hi,
Tap it and use grub/warm screw with may be silicon or some sort to make air tight.
Cheers
Atchi
PostPosted: Thu Jan 10, 2008 1:24 pm
miniswift wrote:
Hi,
Cheers
Atchi
Yep, my throttle bodies have a smaller size injector so I put a m12 tap thru the hole and used short m12 bolts with a washer, the alloy compresses enough when you tighten up the bolts to give an airtight seal.
