It is currently Tue Jan 23, 2018 10:03 pm
 Post subject: 1.0 carb replacement
PostPosted: Sat May 24, 2008 6:42 pm
Have recently acquired an 88 swift in ok condition except for a gummed up carb.
Whats the simplest way out to get this cutie back on the road?
Thanks in advance.
Toolgeezer
 Post subject: Re: 1.0 carb replacement
PostPosted: Sat May 24, 2008 7:35 pm
It will depend on your profile.
If you live in Nebraska vs. the land down under, you will find different responses.
I suggest you look at what Matt Dodd has done.
Search his threads.
PostPosted: Sat May 24, 2008 8:18 pm
Ever thought of just stripping it & cleaning it? It's not that difficult.
Back around '97~'98 - I picked up the '93 that I have - 42 miles on the clock, never registered, sat in a dealer's warehouse after the dealership closed.
To get it running I had to drop the tank, dump the stale fuel, free a stuck fuel pump and clean a gummed up carburetor - I did have the occasional problem with the primary main jet clogging for the first six months or so I owned the car, but it's served me well for 10 years since.
'93 1.3 Swift GLX
'98 2.0 Grand Vitara
PostPosted: Sat May 24, 2008 8:26 pm
I am in South Carolina.
I gave serious thought to a rebuild but am a bit dismayed with the complexuty of the OEM unit. Perhaps that would be the best.
