It is currently Sun Oct 22, 2017 12:44 am
Post new topic Reply to topic  [ 25 posts ]
 Post subject: How to Carb a 1.0 993cc
PostPosted: Sun Sep 28, 2003 6:50 pm
If anyone knows how that would be great, I'm intersted in doing this depending on price might limit when though.
 Post subject: .....
PostPosted: Sun Sep 28, 2003 9:55 pm
Senior Member
Considered running three of a quad carb bike set?
PostPosted: Mon Sep 29, 2003 6:07 pm
But I'm not too sure about it still. I googled, and found this in the old forum... lol
http://pub83.ezboard.com/fteamswiftfrm1 ... 21&stop=29
but I am still unsure of what all I would need and what to do with all the bits (I'm sure I could figure it out, but I would like to know beforhand). Also price is an issue for me as I still am a student.
UPDATE... just as I was gona post I found this site here:
http://www.interlog.com/~lkane/cyc375.htm
http://www.interlog.com/~lkane/torque.htm
and this page here I had never heard of a hypercharger before and am now gonna look for info on that too. This site claims they are making Feul Injected ones, and that the K&N filter can handle "any ammount of rain" sounds interesting..
.... gives me more ideas for my car.
PostPosted: Thu Oct 02, 2003 6:19 pm
What year of 993 are you working on?Would you consider a single 2 barrel?
 Post subject: My Car
PostPosted: Fri Oct 03, 2003 3:51 pm
Its a 94, Canadain. Would a single 2 barrel give any performance upgrade over the stock fule injection? If it would then maybe.... it really all comes down to price and performance for me.
PostPosted: Fri Oct 03, 2003 7:45 pm
I was thinking that a small 2 barrell from a Chevette,or 2.2 Chrysler might work.They are pretty good working holleys.Maybe a throttle body from a 1.3,or 1.6 Suzuki might be bigger.
PostPosted: Fri Oct 03, 2003 8:05 pm
check the sticky setup 'n' look @ the pics of waynes triple carb setup on his 1L in his porsche ..
you'd have a lot more fun 'n' power if you just swapped in a turbo 3 or gti engine.
PostPosted: Fri Oct 03, 2003 11:31 pm
My SOHC 1.3 tb is bigger than my 1.0 tb, but they can't be swapped without some kind of adapter.
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
 Post subject: Carbing my Swift
PostPosted: Sat Oct 04, 2003 12:39 am
That looks pretty decent in the back of the porsche... what are all the parts used and how did it go together? What is the final power output on that thing?
PostPosted: Sun Oct 05, 2003 12:15 pm
wayne custom made (makes?) the adapter plate, you'd want to ask him, however i think he's still off on vacation ..
bolting on a bigger carb to the same old intake isn't going to do you much if any good at all .. and carbs & throttle bodies are entirely different ..
 Post subject: Engine Swap
PostPosted: Mon Oct 06, 2003 3:52 am
I've thought about an g13b swap, but untill I find a donar car for a resonable price thats all I'm gonna do.
PostPosted: Wed Sep 07, 2005 11:04 am
What I plan to do is use a holly 2300 carb. My teacher at FCCJ tells me I would have to change the fuel regulator, and maybe the pump, get higher duration/lift cams and would have to reprogram my ecu for my 94 geo metr0
PostPosted: Wed Sep 07, 2005 2:05 pm
your going to carb it and keep your ecu??? :huh:
Dattman wrote:
PostPosted: Wed Sep 07, 2005 5:58 pm
See, that's what i'm wondering, if I swap my tbi for a carb I won't need my ecu at all I think, or at least I am hoping 8) :twisted:
 Post subject: .
PostPosted: Thu Sep 08, 2005 1:22 am
Senior Member
Keeping the ECU can save you having to do up a fuel-pump cutout circuit, in case of engine stalling, or (hopefully not) an accident.
PostPosted: Thu Sep 08, 2005 8:31 am
The fuel pump cutout on the carby cars is real simple - two diodes feeding the pump relay coil. I assume the FI systems have the same relay setup, so you only need to add the diodes - one feeds from the starter solenoid circuit to run the pump whilst you crank, and the other feeds it from the alternator to run the pump when the engine is running.
PostPosted: Thu Sep 08, 2005 11:00 am
ford uses an inertia switch,so if you get into an accident, it shuts off the fuel supply. also i would run a fuel regulator with a return so you wouldnt have to change fuel pumps..
 Post subject: .
PostPosted: Thu Sep 08, 2005 6:01 pm
Senior Member
I ran mine at 4.5 psi with different springs in the bowls....but generally 2.5-3psi is all you need.
PostPosted: Fri Sep 09, 2005 10:32 am
ok, so change the fuel regulator and have about 2.5-5psi should be good, i just have to make shure that the fuel pump is still pumping and get a cutout circut, and maybe remap the ecu, cool sounds easy, with me and my class we should be able to do it, thanks :lol:
PostPosted: Fri Sep 09, 2005 10:35 am
Your going to have to install an aftermarket in line FPR. The stock one is on top of the TBI unit.
M3----"M" body "3" cylinders.
Now Turbo'd
"M3 like the BMW?"
PostPosted: Fri Sep 09, 2005 10:51 am
right, that big bulgy black thing on to pf the tbi, I planned to get a hks, or greddy one, you know the cool one's with the gauge built in
Fast and Furous/2 Fast 2 Furous dvd pack $14
Ice Man Cool-air intake $175
5" muffler w/turbo spool sound f/x $30
B16A Ctec motor,front walking gear, and install $14,999
KDM manifolds $649
stage 7 3/8 spool happy turbo kit and introcooler $1299
The tunner world from the eyes of a noob
priceless
 Post subject: .
PostPosted: Sun Sep 11, 2005 5:09 pm
Senior Member
If you have a look in my profile gallery, you can see how I set up a 4cyl with these carbs.
 Post subject: Re: Carbing my Swift
PostPosted: Fri Jul 27, 2007 10:35 am
can anyone tell??
PostPosted: Tue Jul 31, 2007 3:37 pm
Thread revival?!
Posted: Fri Oct 03, 2003 9:39 pm lol
PostPosted: Mon Aug 27, 2007 10:54 am
On suzukird.com they have a 1.0 intake manifold that is already set up to use a carb.
I can go 80 going down hill when the wind blows just right...
G-G-G-Geo
