It is currently Thu Oct 19, 2017 11:24 pm
PostPosted: Thu Feb 05, 2009 3:10 pm
hey guys...
I have bought this AFPR for the second time...
I am just a little comfused with the plumbing work...
. the carb i have is a return style carb. it can hold upto 5psi of fuel pressure.
. i will be installing a new electronic fuel pump which has a output of 50psi.
. the carb will get damaged at this hi press.. so i hav bought a AFPR which is also return style.
. how do i connect it?
.............................................................> other line from RETURN of AFPR to TANK.
1: fuel tank > filter > pump > AFPR'S "H/P fuel" >one line from AFPR's "fuel to carb" > carb with BLOCKED RETURN.
2: fuel tank > fuel filter > pump > carb > from carb's return TO low pres. side of AFPR >
from return of AFPR to tank (here the AFPR's hi pressure inlet is blocked)
which one is correct??
File comment: the original connections of AFPR
pic for precedure 1:
File comment: pic for method 2:
PostPosted: Thu Feb 05, 2009 3:20 pm
http://www.malloryperformance.com/pdf/4309.pdf
here 3A represents method 2:
and 3B represents method 1:
I jus want to know if I am connecting the right hose to the regulator.
I will be turbo-ing this car thats why i need this...
PostPosted: Thu Feb 26, 2009 12:05 pm
any help would be great
Last bumped by momed63 on Thu Feb 26, 2009 12:05 pm.
