It is currently Thu Jan 18, 2018 10:28 pm
 Post subject: ITB Specs...
PostPosted: Tue Feb 17, 2009 11:08 pm
I am looking into acquiring some ITBs here soon. I have an friend who works in a bike shop that can get me a set of ITBs for a really good price. I told him ones off a 2000 GSXR 750 would work fine since that is what Lander is using. My friend wants to see if he could find a better set of ITBs for my engine. He was wondering what the spacing is between the intake ports and the sizes of the ports (which I know is hard since they are more ovalish...) If I cant get the answers he is looking for then I guess I will have to take off my intake manifold and let him measure everything. Call me lazy but I don't want to dig out my garage until it gets warmer in a month or so. Any help would be appreciated. Thank you.
Joe
Not owning a Suzuki Swift GT is the path to the dark side.....Non-Suzuki cars lead to breakdowns, breakdowns lead to anger, anger leads to hate, hate leads to suffering, suffering leads to Honda.
 Post subject: Re: ITB Specs...
PostPosted: Wed Apr 01, 2009 4:28 am
Hi,
Our car has 84mm apart spacing.
I think some of bike carbs/ITBs have non equal spacing. I know R1 is for sure.
I think GSXR 750 is what I got and I have to add 4-5mm plate so that all work with 1 throttle cable.
Cheers
Atchi
PostPosted: Wed Apr 01, 2009 5:29 am
Port size is 34mm, gsxr itbs have uneven spacing, cbr 900 is a much closer fit with even port spacing but you will need to alter cable pull ratio.
PostPosted: Wed Apr 01, 2009 6:44 am
Thanks guys. Thats a big help.
PostPosted: Mon Apr 06, 2009 6:49 pm
When I measured them, I got a port size equal to a 36mm hole? If you can find them on ebay, a set of Skyline GTR ITB's work well on a Swift. A couple of guys on redline use them or have used them. Talk to tekkie or moylee or GiTSum
PostPosted: Fri Apr 10, 2009 10:24 am
i have a local guy here who has some CBR1000RR itb's i want to know if they would work ok on a gt? not sure if they would be to big. please hit me up guru's. thanks guys.
HANSTECH
member of team
PostPosted: Sat Apr 11, 2009 4:44 am
my only issue about going ITB is losing the brake booster....something which i cant afford to do so as i'm running 4 pot brakes...
PostPosted: Sat Apr 11, 2009 2:39 pm
The booster is way over rated, personally prefer not having one, much more pedal feel.
PostPosted: Tue Apr 14, 2009 9:53 pm
Mythbusters:
you dont have to lose a brake booster.
Both my Mk3 and Mk1 both use ITB's and retain booster.
PostPosted: Mon Apr 20, 2009 7:15 am
If you look in OzMidnight's album, you will also find quad carbs, with an airbox, fitted in with a booster. That booster was fed off just one runner and had plenty of vacuum, even with cams.
PostPosted: Mon Apr 20, 2009 9:49 pm
or you can link up the runners and have the same amount of vacuum as stock car.
PostPosted: Fri May 29, 2009 3:09 am
tekkie gti wrote:
Mythbusters:
so what Throttle bodies did you use? were they custom machined? i was thinking of the route of using the GSXR 1000 throttle bodies or the honda CBR ones....if i cant find them I'll make do with the 4AG 20 valve throttle bodies....
PostPosted: Fri May 29, 2009 3:10 am
Not when u have 4 piston brakes and u're running on a stock master cylinder...there are times i thought I wouldnt make it when i was stuck in traffic jams due to the lack of vaccum as I'm running Grp A cams...
PostPosted: Fri May 29, 2009 7:51 am
4 banger wrote:
tekkie gti wrote:
Mythbusters:
ITB throttle plates
PostPosted: Sat May 30, 2009 1:21 am
how much was the damage? did u get it custom machined?
PostPosted: Sat May 30, 2009 8:35 am
www.efihardware.com
