It is currently Sun Jan 21, 2018 3:41 pm
 Post subject: ITBs for our swift GTI
PostPosted: Mon Dec 21, 2009 6:31 pm
Hi guys,
What is the best and easy to find tbi to plug on our swift gtis?
Toyota 4AG AE101 ITB ?
GSXR 750 2006/07?
YAMAHA R1 FUEL INJECTION THROTTLE BODY 02-03?
Best Regards,
Miguel
1992 MK3 Euro Swift GTI, Suzukird SS Exhaust header + freeflow SS exhaust + N1 Tip, Suzukird aluminum fuel rail + FPR, 60mm Nissan 200SX TB + K&N Air Filter, Reinforced OEM Clutch + Suzukird Short Shift + Aluminium Flywheel + Gripper 1.5 way LSD 30/70, Apex springs + Koni Sport Shock Absorvers + Wiechers Sport Upper Front Strut Bar + Upper RearStrut Bar + Below Front Strut Bar, Suzukird Underdrive Pulley, 15"x7" Antera Wheels + Bridgestone S03 195/50R15, Kevlar pads + SS Sloted rotors + SS hose kit
PostPosted: Mon Jan 04, 2010 11:16 am
how is the best for the engine G10 3cyl 1.0
PostPosted: Wed Jan 06, 2010 3:22 pm
I run Suzuki GSXR 600 K4 tapered motorcycle injection throttle bodies with a custom made inlet and fully mapped management on my rally car here in the U.K.
http://i220.photobucket.com/albums/dd19 ... G_2306.jpg
makes 155bhp and 120lbft of torque with mild head work, fast road cams and 12:1.1 compression pistons.
Andy.
Drive with commitment or bloody go home!
PostPosted: Thu Jan 07, 2010 1:25 am
Triumph tripple!
As for the g13b I have found CBR900 throttle bodies are the closest fit in terms of size and spacing.
PostPosted: Mon Feb 08, 2010 6:43 pm
What is the CBR 900 years that fit best in our G13B?
Regards,
PostPosted: Tue Feb 09, 2010 2:17 pm
CBR 600RR also fits...
PostPosted: Fri Mar 05, 2010 2:24 pm
Andy.
is that wheel horse power or crank? :huh: ...that's impressive!
1994 Suzuki Swift GTi
PostPosted: Fri Mar 05, 2010 3:14 pm
Flywheel HP, 130 something at the wheels and only wieghs 730Kg :D .
PostPosted: Fri Mar 05, 2010 8:37 pm
that's pretty impressive! can you elaborate a little more on the specs. of the engine?
PostPosted: Tue Mar 16, 2010 5:56 pm
What is the years for the cbr 900 and 600RR?
Do I should buy TB, TPS and injectors, or do I should use Swift TPS and Injectors?
Should I buy SR20DET injectors for this application?
Regards,
Miguel
PostPosted: Wed Mar 17, 2010 3:37 pm
you have a PM
