It is currently Tue Oct 17, 2017 9:30 pm
PostPosted: Tue Dec 29, 2009 6:05 am
hey my mk 1 has a aisin style carby and i do ow much fuel it uses... Should get 4.4L to 100km but instead getting about 10 so its drinking a LOT of fuel... Anyone know what i can do to lean it off and tune it up? Also any other ways to reduce fuel consumption?
PostPosted: Tue Dec 29, 2009 12:29 pm
Maybe you need to reset the level on the float.
Also, after you do that, use one of these
to adjust the idle/air mixture screw.
You don't have to buy one, but someone locally will have a similar machine for checking CO in the exhaust.
First, of course, you have to check for codes and do a compression test.
:thumbsup: :thumb2: :thumbsup: :thumb2: :thumbsup: :thumb2: :thumbsup: :thumb2:
Now, weren't carbs easy?
PostPosted: Tue Dec 29, 2009 1:52 pm
i have the same with my 1985 swift mk1 gs with vacuumcarb
driving almost like a granny it consumes 1 liter every 12 tot 14km
i got 3 gti""s which used less fuel (same fuel but driven like a sportcar)
sport "07,mk3 "92 gti,mk1 "85 gs, "86 rg 125 gamma
suz_history: "91 mk2 gti rascal, "95 mk3 gti,"90 mk2 gti, 99" gsx_R 750 dragstyle/chrome/polish
PostPosted: Tue Dec 29, 2009 10:32 pm
hmm ok so how do i re-set the float and where is the float... I know carbies are easy but well... never had much to do with them havnt had a carby car since i was 17 lol
PostPosted: Tue Dec 29, 2009 10:34 pm
p.s. Check for codes? My car doesnt have sensors... Its literally just an engine lol.. The only real sensor is for the temp guage no computer controlled anything go a single wire for the electronically assisted solenoid thats it
PostPosted: Wed Dec 30, 2009 9:47 am
So, how do I reset the float?
So, where is the float?
LOL
Now, you want to read about carburetors?
Check this out; there's a pretty good explanation of a carb which is a tad bit more complicated than your Aisin here:
http://s145.photobucket.com/albums/r211 ... ?start=all
So if you read that whole album, it should be easy to fix your carb.
Don't forget: nothing gets done until after the compression test, right?
Cheers, mate.
Users browsing this forum: Majestic-12 [Bot] and 1 guest
