It is currently Tue Feb 20, 2018 12:07 pm
 Post subject: G13B Copper Head Gasket
PostPosted: Fri Nov 19, 2010 8:29 pm
Hello,
This is my 1st post here...I found this forum from this website -
http://www.occracing.com/
They claim to sell a copper head gasket for the Samurai as listed on this page -
http://www.occracing.com/pricing.htm
CGAS-100 Copper head gasket (sizes available)
0.032", 0.043", 0.050", 0.062", 0.080", or 0.090" PRICED EACH $125.00
Does anyone have any pros/cons to running a copper head gasket?
I'm in the process of rebuilding my g13 and was thinking about using a copper head gasket...
Anyone with any info would be much appreciated!!
Thanks!! :mrgreen:
PostPosted: Wed Nov 24, 2010 3:56 pm
it's a reusable gasket that wont be blown easely with high compression.
I would use one if the price would be right.
G13B 1.3L 16v 115hp
PostPosted: Tue Dec 21, 2010 6:29 am
I tried them on my hi compression G10 engine. It kept blowning right away. I have used them on HiComp V8s. And they worked great. But the torque specs on the G10 are 55 ft/lbs. I also tried several different techniques to install them. Still no good. I got mine from Innovative Machine in St. Louis. Mo About the same price
PostPosted: Sat Oct 15, 2011 12:12 pm
With a copper headgasket you have to Wills Ring the head and block, so when the copper is compressed it fills the two small grooves (1 head, 1 block) on each cylinder.
Have you thought of using genuine Suzuki items as they are multi layer steel (such as Cometic etc), I'm running 12.1:1 compression on a 77mm bore (1362cc), I used a genuine Vitara MLS headgasket held down with ARP studs and nuts and have had no problems with it at all.
Drive with commitment or bloody go home!
PostPosted: Tue Apr 24, 2012 3:59 pm
I run copper gaskets ...The only thing I need to use is a hi temp sealant like coppercoat or graphite grease and that`s all.
android apps development
