It is currently Thu Jan 18, 2018 5:16 pm
 Post subject: want itb tips
PostPosted: Thu Dec 02, 2010 2:09 am
hi guys!
i am going to convert my gti i have a set of gsxr 750 itb and as i say in the subject i am searching for tips
i found some info's but they are all scattered in many topics and they are old!
does any one have something to advice me?
examp 1)what about the gsxr tps?
2)what about the maf?
3)the 2 ports of the itb would work fine?
4)the injectors?
thanks!
 Post subject: Re: want itb tips
PostPosted: Tue Mar 01, 2011 8:15 pm
thats someone would say something... im asking the same question. ive been doing some research myself. what i have figured out is to use a mega squirt ems and learn how to set a tune. get a map sensor from a honda ior GM one thats very popular. set the tune for a map sensor input delecting the maf. u will have to find a flow chart showing values per rpms and map it. also would have to look at the tps to determine load. once u get that figured out buy a flange from ebay
http://cgi.ebay.com/ebaymotors/Suzuki-S ... 2eb0480b12
get some cuplers for the tb's to mount up with the manifold. for the fuel rail in thinking about getting a custom one made.
its more of a tuning nightmare then anything else
'94 Swift GT - back in the game at full force !!
'96 Nissan 200SX SE-R SR16VE N1 power with all the goodies possible
Looking for gsxr itb's already set up ... Let me know
PostPosted: Sun Jun 09, 2013 8:56 pm
all gather from internet, and the internet never lies! :wink:
problems with vacuum signal. so either MAP sensor or dizzy problems.
link each runner together to lessen vacuum variations.
longer runners better for this than shorter.
tps might or might not work.
you will need aftermarket standalone fuel system. probly bigger injectors.
might be a problem in mark 1 heads.
-vernon wasser-
88 sprint, 4dr sold :(
87 turbo 2dr, never ran :( :(
86 sprint, 2dr current DD! :)
PostPosted: Thu Jun 13, 2013 9:47 am
Why?
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Fri Jul 12, 2013 2:36 pm
mark I have a carb, and coolant running through the intake manifold. the thermostat is on the intake.
you could make one up, steel would be easiest for welding, but that would be a lot of pieces to weld.
the mark II have no coolant running through them.
-vernon wasser-
