It is currently Thu Oct 19, 2017 7:12 am
 Post subject: distributors ...
PostPosted: Fri Nov 28, 2003 12:35 am
I was wondering if the distributor off of the swift 8v will work on the swift 16v head?? I am running carbs so the stock dist. won't work because it runs off the computer.. And Ias told the 8v dist. is mechanical advance.. Any input on this.. Or info from the carb guys??
THanks Alot, Scott
You Just Gotta Beast It!!
PostPosted: Fri Nov 28, 2003 2:21 am
hey scott, you have a carb setup already ?
i'm looking into the same issues, check the carbs section ..
i'm even in seattle for a few days ..
cheers
PostPosted: Fri Nov 28, 2003 2:32 am
I am running a quad carb set-up on my 92 gt and i am using a distributor off of a 8 valve motor. it is vacuum advance
Why are all the HONDA'S scared of me i'm only a 1.3L
PostPosted: Fri Nov 28, 2003 5:59 am
Not all 8V distributors are mechanical, my 1992 Swift engine is all electronic. Might need to be from a carbureted car.
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
 Post subject: .....
PostPosted: Fri Nov 28, 2003 7:21 am
Senior Member
Mk1 dizzys are not computer controlled. Mine is now full-mechanical with a modified curve.
PostPosted: Fri Nov 28, 2003 12:28 pm
so was the 8v dizzy a simple bolt on ? what about the 3cyl distributors ? a whole lot more of them @ the wreckers as well ...
 Post subject: .....
PostPosted: Fri Nov 28, 2003 10:22 pm
Senior Member
The 3 cylinder dizzy will not work...
PostPosted: Fri Nov 28, 2003 10:58 pm
figured they wouldn't be a straight swap (only 3 cylinders of course), but the shaft, mounts, weights, springs, etc... ?
@ least if a 8v one can be fitted to a 16v head ..
PostPosted: Fri Nov 28, 2003 11:39 pm
So I need a distributor off of a carbed 8v swift to run this setup?? That is what it sounds like. NItro- yeah I got the motor stripped got my mallory hyfire val ignition, dual mikuni 40phh carbs, fuel pres. reg.. So all I need is the distributor. And my manifold to run the dual carbs (already got one lined up).. I am putting this motor in my 86' samuri.. it is an offroad setup..
Later, Scott
