It is currently Wed Jan 17, 2018 8:48 am
PostPosted: Fri Apr 15, 2011 11:57 pm
Hi guys I'm new to this, but I've got a G13A motor that I just had the carburetor re-kitted on and the vacuum advanced on the timing seems like it is coming on too soon, therefore pinging. I noticed a few of the vacuum lines were put back in the wrong places. I think this might be the case.
Any chance someone has a picture of the back of the carb where I could see the vacuum advance port?
PostPosted: Sat Apr 16, 2011 8:23 am
Try the distributor vacuum on the top vacuum line.
Cheers
