It is currently Wed Oct 18, 2017 10:52 pm
PostPosted: Fri May 06, 2011 3:30 pm
Hi everybody,
i have a swift gti engine with T/B s. I am using standalone Dictator ECM. Car wont start up, because there is no spark. Have changed a distributor and ignition coil but still the same. What could be the problem? I have tested ECM and it works fine, also we have tried to check the problem with software and there was info that ecm wont get info about engine revs.
Help is needed :)
Best regards,
Luka
.: www.suzuki-klub.com :. SUZUKI KLUB SLOVENIJA
PostPosted: Sat Oct 15, 2011 12:01 pm
Do you need to run an engine crank sensor plus a TPS, because if the ECU requires a signal from the crank sensor and you don't have one it wont spark.
Drive with commitment or bloody go home!
