It is currently Thu Oct 19, 2017 3:58 pm
 Post subject: soo many vacuum lines!
PostPosted: Thu Mar 04, 2004 11:27 pm
Question time yet again...
When clearing out the bay and removing all unneccisary componants, what, if any, vacuum lines do i need to keep in order to keep running? I.E. Evap canister and such..
Since im eleminating at least 90 percent of the componants that use the lines, then do i just remove those as well?
Thanks guys!!
90 Geo 1.0 3x mikuni carb swap.
 Post subject: vacuum lines....
PostPosted: Fri Mar 05, 2004 12:37 am
i did a carb swap. the only vacuum lines that you will need are the ones for the brake booster...
as far as i can remember
Why are all the HONDA'S scared of me i'm only a 1.3L
 Post subject: .....
PostPosted: Fri Mar 05, 2004 8:21 am
Senior Member
Unless you have a bunch of pollution people to satisfy.... :roll:
PostPosted: Fri Mar 05, 2004 7:27 pm
very true. but hear in canada no one gives a shit...
PostPosted: Sat Mar 06, 2004 2:14 pm
Not true, in B.C. in the lower mainland you must pass Air Care A.K.A, Air Scare. It is another scam road tax on people that live in the lower mainland.
PostPosted: Sun Mar 07, 2004 10:57 pm
True, but AirCare never looks under the hood, the usual procedure is pressure test the gas cap, look for something resembling a cat under the car, and emissions testing. I think for newer LEVs they also code scan the OBD, but I've only ever brought old beaters through AirCare :wink:
 Post subject: smog
PostPosted: Mon Mar 08, 2004 10:58 am
air care is a good thing. there are so many people in the lower mainland. the smog is bad enuf right now.
scam road tax... road taxes are good. will pay for the new bridge needed down that way.
PostPosted: Mon Mar 08, 2004 2:30 pm
i've seen some pretty poorly tuned and worn out cars get through aircare .. it's amazing what a difference a cat makes .. it's not a perfect system, but at least you don't see nearly as many gross polluters driving around .. you just have to head out to the unregulated areas to get a reminder of the crap people will drive if they can get away with it, billowing clouds of smoke from their tailpipes ..
if you want to complain about money grabs, then it's all about ICBC & their bogus insurance monopoly ..
 Post subject: .....
PostPosted: Mon Mar 08, 2004 7:31 pm
Senior Member
To "register" a 4 cylinder here for a year for road use, it will set you back $582....so stop complaining, guys....... :P
PostPosted: Mon Mar 08, 2004 8:03 pm
in nz my insurance w/ all the bells & whistles was about $250nz/year + $60reg ..
it would have been almost $400 w/o any discount ..
 Post subject: .
PostPosted: Mon Mar 08, 2004 8:12 pm
Senior Member
Insurance is a whole different matter....all mods disclosed for me is about $390Aus this year.
PostPosted: Thu Mar 11, 2004 10:22 pm
as for the booster line....since im fabricating a new manifold as we speak, where would be a good place to tap into for the booster line?
 Post subject: .
PostPosted: Sat Mar 13, 2004 11:49 pm
Senior Member
Inbetween the butterfly and the valve. You can tee-off all four if you like.
PostPosted: Tue Mar 16, 2004 5:59 pm
The mad quebecer
The mad quebecer
Is it for turbocharge purpose?
PostPosted: Tue Mar 16, 2004 6:45 pm
Jard: No, this is for the brake booster...
Although i have a few questions that are turbo/ carb related for ya if ya dont mind?
'90 Geo "Retro"- 3x Mikuni Carb 1.0
Custom ground performance Cam
Custom advanced timing cam gear
MSD 6al control, coil, wires.
2" exhaust from the hollow cat back
Short throw shift
front & rear strut bars
lowered 1.5"
 Post subject: .
PostPosted: Tue Mar 16, 2004 7:03 pm
Senior Member
He was asking if you were intending to turbocharge the car.
PostPosted: Tue Mar 16, 2004 7:30 pm
I must have mis-understood. I took it as he was asking if the "booster" off the intake was for turbo.
But yes, i am planning on turbocharging after i get the carb task finished!
Short throw shift
lowered 1.5"
 Post subject: .....
PostPosted: Wed Mar 17, 2004 12:18 am
Senior Member
If you are planning on turbocharging for sure.....just tap into the bosses on your cylinder head (look inside the ports) and use GTi injectors and cut down rail. Have a plenum made up with whatever TB you like. Injection is so much nicer for force-fed stuff.
