It is currently Tue Oct 17, 2017 10:14 am
 Post subject: Lower the fuel pressure
PostPosted: Tue May 18, 2004 6:49 am
Hello,
I’ve got 2 Weber 40 DCOM carbs on my Mk3 swift Gti so I have to lower my standard fuel pressure. I hope to do this with a simple standard fuel pump of a 1.3 carb swift. Can this be done en will this work properly?
PostPosted: Tue May 18, 2004 8:29 am
Senior Member
It should be ok...as long as you fit a good fuel reg inbetween the pump and carbs.
PostPosted: Tue May 18, 2004 8:49 am
A good fuel reg? You mean a fuel pressure regulator? This is also on the standard carb swift or why do I have to do this?
And does anyone know if this carb pump is plug and play on my GTi fueltank?
PostPosted: Tue May 18, 2004 2:19 pm
you will also want to plumb in a return line for the fuel off of the regulator. That option should come with the regulator.
'90 Geo "Retro"- 3x Mikuni Carb 1.0
Custom ground performance Cam
Custom advanced timing cam gear
MSD 6al control, coil, wires.
2" exhaust from the hollow cat back
Short throw shift
front & rear strut bars
lowered 1.5"
PostPosted: Wed May 19, 2004 8:20 am
So, why do I need a new pump then? Can't I just use a regulator on my standard pump? This is about 8 bar (117 psi)? So I have to lower it to around 0,5 bar (7 psi). Or is there to much difference between those to values?
PostPosted: Wed May 19, 2004 5:23 pm
Im sure you could just run the stock pump, But, i Think the contrast in pressure would lead to trouble somewhere.
Short throw shift
lowered 1.5"
 Post subject: .....
PostPosted: Wed May 19, 2004 10:39 pm
Senior Member
Your EFI pump would have a heart attack. You need to run a low pressure pump. Bought a Facet pump for my car, new, for all of $75Aus. Chuck a filter between tank and pump and a reg inbetween pump and carbs. Plumb the carb return line onto the old EFI return line.
 Post subject: Re: .....
PostPosted: Mon May 24, 2004 2:12 am
Carb return line? Whats the carb return line?
 Post subject: fuel pump
PostPosted: Tue May 25, 2004 5:12 pm
i took FI off of a ford truck that has 2 pumps one in the tank and a booster pump mid way. these make 90 psi .i hooked the fuel line to the return line with a T fitting and hooked the carb to the side of the T. with the check valve in the tank, this gives about 6 psi at the carb ( holley 600) it has run about 30 K miles with no troubles. cost $2.00.
larry
 Post subject: Re: fuel pump
PostPosted: Thu May 27, 2004 7:48 am
larry
That’s exactly what I'm trying to do now. I went to my local dealer an they told me to do it like that. I can at least try and see what happens. When I fail I can always buy the expensive stuff.
