It is currently Sun Jan 21, 2018 3:35 am
PostPosted: Tue Jun 15, 2004 12:16 am
I have just converted my 89 mk2 to carb's and i would like to now what else i must do to run mid 14's all motor[/img]
PostPosted: Tue Jun 15, 2004 7:09 am
Since you didn't list any other mods:
* high comp pistons
* get head decked
* port/polish
* oversized valves
* headers
* exhaust
* LSD
* slicks
* remove all your dead weight! your interior weighs 140 lbs!
 Post subject: .....
PostPosted: Tue Jun 15, 2004 8:21 pm
Senior Member
Trim out 100kg...some mild cams and cam gears...and make sure you fit a decent-sized airbox to your carbs that is fed by cold air, not by hot underbonnet air. Firm up that back suspension to help prevent weight transfer and get some decent sticky tyres, as well.
PostPosted: Wed Jul 21, 2004 10:50 am
Lihtan thank
and what is " get head decked "
Where can I buy a good header and some good suspensions too
what compression ratio of pistons ???
Thank ozmidnight
PostPosted: Wed Jul 21, 2004 7:36 pm
miracle wrote:
and what is " get head decked "??
schaaf e head.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Thu Nov 18, 2004 5:59 pm
Hi,
I think "get head decked" means that machined to increase compression ratio.
What CR can you safely run with 95 octan petrol?
Get yourself a mk1 dizzy otherwise I don't think your car will run.
How about fuel pressure?
Did you get your injection fuel pump swapped to low pressure item?
You will need to have pressure regurator, since most of bikes are run gravity feed not pumped so any pump set up will need to run with regurator.
I think you need to get your car drivable before you start to mod all in one go.
Otherwise, you will be having fun time solving faults.
May be you might get lucky.
Good luck and let us know how you get on.
Cheers
Atchi
