It is currently Tue Oct 17, 2017 6:05 pm
PostPosted: Thu Jul 15, 2004 4:03 pm
hey all, I was wondering what people have their dual carbs jetted at as far as mains, as well as what venturi sizes people are running.?.
I am asking because I am running dual mikuni's 40phh's on the DOHC motor, they are stock as far as i can tell.. And am wondering what these size carbs have for stock setups, and what they should be changed to..
I was also told that going down to about a 27 venturi would be better suited for this motor.. I don't know a whole lot about carbs but I have messed with them as far as getting everything in tune..Just wondering what some people are running..
Thanks, Scott
You Just Gotta Beast It!!
 Post subject: .....
PostPosted: Fri Jul 16, 2004 1:16 am
Senior Member
bdgracia is a great guy to talk to about jetting Webers....
PostPosted: Fri Jul 16, 2004 9:15 pm
Not sure for a stock engine since my engine is not stock :D
By the way I have weber 45DCOE.
Bolivar
PostPosted: Sat Jul 17, 2004 10:17 pm
What mods do you run?? what carb settings??
Thanks, Scott
 Post subject: .....
PostPosted: Sun Jul 18, 2004 12:40 am
Senior Member
Oops, sorry Bolivar...for some reason I thought you were running 40's.......thus leading to the thought you might have some ballpark figure for sco44 to get started on. :oops:
PostPosted: Wed Nov 09, 2005 12:57 pm
Bolivar
Would you or anyone else be willing to share what jetting and what sized venturies you are using?
Mk1 t3!
PostPosted: Wed Nov 09, 2005 2:56 pm
My last engine with 40DCOE's was pretty much standard except for some head work.
I was running :
32 Chokes
Mains 155
Air Correctors 160
Emulsion Tubes F16
40 F8 Idle Jet
40 Accelerator Pump Jet
Only guide line. Rolling road is the only way to set up properly.
Dara
Mk1 Gti Rally Photos @
http://homepage.eircom.net/~kellsstainless
 Post subject: .
PostPosted: Wed Nov 09, 2005 4:09 pm
Senior Member
In other words you were running 32mm Webers... lol
PostPosted: Wed Nov 09, 2005 10:54 pm
is the jetting on mikuni's referred to the same way you stated yours??
Thanks ,Scott
PostPosted: Thu Nov 10, 2005 10:34 am
I was running :
32 Chokes
Mains 155
Air Correctors 160
Emulsion Tubes F16
40 F8 Idle Jet
Dara
Thanks. I was just looking for a general idea of where to start.
Mk1 t3!
PostPosted: Thu Nov 10, 2005 8:15 pm
my jetting on dual 40 mm mikuni's, full exaust intake porting.
12.5 mm float setting
34mm venturi
main jets- 140
pilot jets- 57.5
main air jets- 180
how does this look to carb experts, also what timing should I run?
Scott
PostPosted: Fri Jul 27, 2007 10:53 am
what are the beneficts from going on carbs?? :oops:
PostPosted: Fri Aug 14, 2009 3:39 pm
I'm running twin dhla carbs with 34 mm venturi
mains 147
air 170
normal emulsion tubes
50 idle jets
( not enough power with these jets , i'm thinking maybe the venturis are too big for this engine)
I've had them on my last engine running 32mm venturi
mains 130
air 170
rich emulsion tubes
50 idle jet
(ok about the power but only in the upper rpm band above 5500)
Tomorrow i will try 30mm venturies with different jets to see if they respond better in the middle rpm range from 4000 to 7000
G13B 1.3L 16v 115hp
PostPosted: Wed Dec 23, 2009 4:04 pm
any idea on the approximate cfm for the pair of carbs?
PostPosted: Sat Jan 02, 2010 12:22 pm
no ideea , but they'll go to over 9000 rpm on 34 mm venturi with the corect jets
G13B 1.3L 16v 115hp
