It is currently Sat Feb 24, 2018 10:57 am
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Jun 25, 2005 3:19 am
spt-3x1.0 wrote:
GASOLINE FUMES:When you stated your 92 swift sedan w/ 1.3 sohc has a 3.52 tranny was you referring to the four door cause in some years the four door swift was different style then the four door metros of the same years?
I never said sedan, it was a 2-door hatchback.
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
PostPosted: Fri Aug 05, 2005 2:58 pm
according to hollender interchange book 89-94 3 cyl metros are 4.10 ratio and the xfi is 3.89
PostPosted: Sun Aug 28, 2005 3:50 pm
what would be the best tranny for 0-60mph 4.39 or 3.89. i don't care for highway speeds i jsut want off the lights acceleration. anyone with good exp or info fill me in cause im gettign confused.
PostPosted: Mon Aug 29, 2005 4:27 am
You'll want the 4.39 for quicker acceleration.
PostPosted: Mon Aug 29, 2005 11:17 am
thanks gasoline fumes
PostPosted: Thu Nov 17, 2005 8:39 pm
OK-after the numbers are all bouncing in my head!-can someone tell me what i need to find to fit my 91 metro 3cyl 5-speed? I want the best gear for gas mileage that will bolt right up? RPO codes i can look at? thanks!
PostPosted: Fri Nov 18, 2005 12:42 pm
to get best mileage without killing your clutch either put in a XFI tranny or run some 13" tires
PostPosted: Fri Nov 18, 2005 1:39 pm
well, i was thinking a 3.5 trans with 13" tires. Or, would that just be bad? I'm not worried about take off speed, just low rpm's at highway speeds.
PostPosted: Fri Nov 18, 2005 2:14 pm
you could barely get car to move with 3.5 and 13" tires. never be able to take off on a hill, if you must kill the power go with xfi tranny and the 13". try the 13" tires first. think you will be supprised how much slower it is to get going
PostPosted: Fri Nov 18, 2005 2:43 pm
I have to agree, you'll need to be REALLY dedicated to not caring about takeoff with 13's alone... I put em on mine and now my car doesn't really accelerate, it slowly finds its way to 60 mph.
if you truly dont' careabout acceleration, get 13's first, THEN play with gear ratios after a while of driving it like that.
As always, YMMV.
PostPosted: Sat Nov 19, 2005 2:26 am
But the 1989-94 SOHC 1.3L Swifts came with the 3.52 final drive and 155/70-13 tires from the factory. :lol:
PostPosted: Sat Nov 19, 2005 6:59 am
To do both would be extreme, the XFI came with 3.9 gears and 12" wheels, but it was tuned for low rpm torque. 13" would be a big difference, and 3.5 gears would also. Both together would be dangerous when trying to merge, etc. I've got some stock mk5 wheels I'd let go cheap, they're just not worth shipping. If you can drive down to the PA line near Baltimore, I'm willing to drive up there. They've got factory tires with a little bit of tread left. Starting to get a little slidey in the rain, but enough to be legal.
PostPosted: Sat Nov 19, 2005 12:18 pm
yes, the 1.3 came with the taller gears and tires but its a 4 cyl and has a lot more torque to get the car moving
PostPosted: Sun Nov 20, 2005 6:27 am
For some reason I forgot about the extra torque. :oops:
PostPosted: Mon Nov 21, 2005 5:07 pm
Woodie-thanks for the offer, but i actually have a 95 or 96 automatic Metro i'm trying to get rid of and do have another set of wheels. The metro was bought from a friend of my sisters, but he beat up every panel messin around with one of his buddies. I like the older style metros anyway. If someone would want it; i think my uncle wants $650 for it. I think it has like 70,000 miles on it or something. He just put 2 nice fenders and a hood on it. He was gona paint it and drive it, but he says it's too small.
I also found 2 XFi's in the yard-with trannies!! They are the 3.79 ratio 5speed. One still has the head and cam laying there and the engines are in both! Is the cam in the XFi the same specs that Superf1y is grinding to?
Waht about 14" tires? How would i calibrate the speedo btw?
Thanks!
PostPosted: Mon Nov 21, 2005 6:32 pm
I'm positive the XFI cams are different than anything Suprf1y is grinding. I do remember a post about his economy cams, you might look for it. i thikn it's a review. I think it referred to the xfi cams and the diferrences between it and his econ cams. don't shoot me if i'm wrong though.
PostPosted: Mon Nov 21, 2005 8:48 pm
They are close enough that I have advised a number of xfi owners to stick with what they have, rather than spend the money on my cam. The results would be indistinguishable.
I will take one if you can get it, though. I would like to do some bench testing.
PostPosted: Tue Nov 22, 2005 10:51 am
I'm just not gonna post anything anymore... :oops:
PostPosted: Tue Nov 22, 2005 7:03 pm
STuPiDiCuS-dont worry; i would like to think suprf1y is like myself. These forums are not for "flaming" as i see it so-called; they are for information and comradery(<--think thats spelled wrong) and the bringing together of common interests in the name of science--and most importantly---FUN!!!
suprf1y-i was planning on keeping the one cam i found, but if bench testing is your angle; then you will be the first i notify if i find another.
No one knows how to calibrate the speedo?
PostPosted: Tue Nov 22, 2005 7:12 pm
Oh, have a member on here interested in a tranny, but i wont be able to get it for 3-4weeks. If he decides he does not want it; i will let you know. I think i can get it for $80-85.
PostPosted: Wed Nov 23, 2005 12:51 am
...and the bringing together of common interests in the name of science...
That includes you guys in Kansas as well! :razz:
 Post subject: Checking diff ratio
PostPosted: Wed Nov 23, 2005 2:38 am
Hi:
possibly dumb question, I have a choice of a few transmissions to put behind my MarkII T3,none of them that I really know much about the condition of
#1 is T3 transmission
#2 is 1.3SOHC transmission,which fits except for a couple minor bracket issues.
I have put a T3 transmission in a swift 1.3 SOHC and difference was unnoticeable.
What I would like to do is check diff ratios,with the transmission on the ground what do i have to do, to get at the crown & pinion so I can check gear ratios(diff).
thanks,Jewar
 Post subject: Re: Checking diff ratio
PostPosted: Wed Nov 23, 2005 8:35 pm
jewar wrote:
Hi:
thanks,Jewar
I can't say for the T3, since those were never marketed down here, but based on dealership brochures the tranny ratios for the gears in the 1.0, 3 cyl and 1.3, 4 cyl SOHC cars are identical - the only difference being the final drive
PostPosted: Wed Nov 23, 2005 9:46 pm
Jewar, the turbo 3 tranny has 4.10 ratio, while the 1.3L SOHC one SHOULD have 3.79 or whatever it is. Also, the turbo tranny has a stronger diff IIRC (I'm not to up and up on the 4 cylinder cars). Are you planning on putting more power than a little over stock output through the tranny? If so, stick with the turbo tranny IMO.
GeoZukiGTi wrote:
CJDavE wrote:
Chassis Flex Motorsports
