It is currently Thu Jan 18, 2018 1:17 am
PostPosted: Thu May 25, 2006 11:53 pm
banned
I have 3 different trannys to use for my Metro to gt swap. One's a GT tranny, one's a metro vert tranny, and one's a stock metro 1.0 tranny. I was thinking about mating the gt engine to the vert tranny to give it some more umph off the line, but will it just make it uncontrollable on takeoff? I plan on leaving the engine stock aside from an upgraded throttle body and 2 inch exhaust with glasspack. Help me guys, I dont want to regret my decision and pull the tranny out again. Synchromesh isnt cheap.
PostPosted: Fri May 26, 2006 12:39 pm
the GT trans has heavier components inside. For example the ring and pinion are much beefier in the GT.
Tony
Proud owner of :
1970 AMC AMX
1989 Suzuki Swift GTi (gone, my baby is gone :( )
1993 T-Bird
PostPosted: Fri May 26, 2006 2:17 pm
Mama Said Knock You Out!
I've had a vert tranny in my GTi swap for a while now, and I'm much happier with it. I've had synchros fail, but never a diff fail. Yes, the vert diff is a weak point, but unless you're running 300hp behind it, I don't think you'll have a problem in the future.
TGstring wrote:
sooooo clean it's duuuuurrty.
PostPosted: Tue May 30, 2006 10:59 pm
banned
Do you think that traction will be a problem with the vert tranny? Does takeoff seem noticably improved with the vert tranny versus the gt tranny?
