It is currently Fri Feb 23, 2018 1:39 am
PostPosted: Sat Aug 12, 2006 8:53 am
This is the entire manual transmission section from the Suzuki SA310 factory service manual. This information will cover transmission servicing for manual transmission MK1 vehicles (Suzuki SA310, Forsa, Sprint & Firefly). Now updated to include details about the 4 pinion differential featured on turbocharged models.
7A-1 Transaxle Contents, General Description
click for full image
7A-2 Transaxle Cross-section
7A-3 Transaxle Exploded View
7A-4 Gear Shifting Mechanism
7A-5 5th & Reverse Shift Cam
7A-6 Diagnosis
7A-7 On Car Service - Checking Oil Level
7A-8 Gear Shift Control Components
7A-9 Gear Shift Control Lever Adjustment
7A-10 Tightening Torque and Lubrication Points
7A-11 Fifth Gears
7A-12 Fifth Gears con't
7A-13 Fifth Gears con't
7A-14 Fifth Gears con't
7A-15 Fifth Gears con't
7A-16 Gear Shift and Select Shaft Assembly
7A-17 Gear Shift and Select Shaft Assembly con't
7A-18 Gear Shift and Select Shaft Assembly con't
7A-19 Gear Shift and Select Shaft Assembly con't
7A-20 Transaxle Assembly
7A-21 Transaxle Assembly con't
7A-22 Unit Repair Overhaul - Disassembly of Transaxle
7A-23 Unit Repair Overhaul - Disassembly of Transaxle con't
7A-24 Unit Repair Overhaul - Transaxle Right Case - Right Bearing Cups and Input Shaft Oil Seal
7A-25 Unit Repair Overhaul - Transaxle Right Case - Reverse Gear Shift Lever, Differential Side Oil Seal, Gear Shift Shaft
7A-26 Unit Repair Overhaul - Transaxle Right Case - Gear Shift Shaft con't
7A-27 Unit Repair Overhaul - Transaxle Left Case - Gear Shift Forks and Shift Shafts
7A-28 Unit Repair Overhaul - Transaxle Left Case - Input Shaft Assembly
7A-29 Unit Repair Overhaul - Transaxle Left Case - Countershaft Assembly
7A-30 Unit Repair Overhaul - Transaxle Left Case - Countershaft Assembly con't
7A-31 Unit Repair Overhaul - Transaxle Left Case - Countershaft Assembly con't
7A-32 Unit Repair Overhaul - Transaxle Left Case - Countershaft Assembly con't
7A-33 Unit Repair Overhaul - Transaxle Left Case - Differential Assembly
7A-34 Unit Repair Overhaul - Transaxle Left Case - Differential Assembly con't
7A-35 Unit Repair Overhaul - Reassembly of Transaxle
7A-36 Unit Repair Overhaul - Reassembly of Transaxle con't
7A-37 Unit Repair Overhaul - Reassembly of Transaxle con't
7A-38 Unit Repair Overhaul - Reassembly of Transaxle con't
7A-39 Unit Repair Overhaul - Reassembly of Transaxle con't
7A-40 Unit Repair Overhaul - Required Service Materials
7A-41 Special Tools
7A-42 Special Tools con't
<hr>
EPI Turbo supplement
This contains info on the 4 pinion differential unique to MK1 turbos:
Section 7A Transaxle (Contents, General Description)
7A-2 Differential Exploded View
7A-3 Unit Repair (Disassembly)
7A-4 Unit Repair (Disassembly con't, Assembly)
7A-5 Unit Repair (Assembly con't)
7A-6 Unit Repair (Assembly con't, Reassembly of Transaxle)
EDIT: updated to include turbo tranny info
PostPosted: Sun Aug 13, 2006 4:03 pm
Did the Mark 1 GTI have the same four pinion diff, that the Turbo has?
...I know my 1989 GTI (Mark 2) does not. Darcy
PostPosted: Sat Aug 26, 2006 2:52 pm
Updated to include turbo supplement data about the 4 pinion diffs.
PostPosted: Fri Sep 08, 2006 8:11 am
thanks for the info!!
PostPosted: Thu Sep 14, 2006 10:22 am
Hey lithan, would you happen to know if the internals from and MK1 box would fit into an mk2 case?
Thanks
Ryan
PostPosted: Fri Sep 15, 2006 7:06 pm
Thanks
Ryan
Ryan,
DMWDave has played with the idea but he reported on redline forum that the internals are different.
There is a way to fit mk2/3 diff housing in once you modify the outer bearing. But the rest of the box is not directly swapable.
PostPosted: Sat Sep 16, 2006 1:46 am
The MK1 and the MK2/3 bellhousing patterns are identical. I've personally testfitted a MK3 GTi bellhousing onto an '88 Sprint engine, and everything lines up perfectly. Why not just use the MK1 tranny, and make new tranny mounts, and modify the driveshafts?
PostPosted: Wed Mar 18, 2009 12:58 am
Just updating an old sticky with a link to Phil n Ed's mk1 disassembly how to guide.
http://www.teamswift.net/viewtopic.php?f=9&t=42589&p=321675#p321675
To answer a previous question, yes the mk1 gti does have the same 4 pinion diff as the mk1 turbo.
PostPosted: Tue Nov 15, 2011 12:52 am
Zero of these links work for the manual. Error 404, not found is the message I get for all of them. :cry:
PostPosted: Tue Nov 15, 2011 1:58 am
SOMEhow the link that i posted dissappeared.
PostPosted: Tue Jul 02, 2013 4:54 am
Is the link to the pictures broken for this post?
Fainya
