It is currently Wed Jan 17, 2018 4:50 am
PostPosted: Thu Nov 22, 2007 10:07 pm
UPDATE: The problem was with the speedometer all along.
RPM's are fine.
I have a 91 metro vert. The clutch pedal is really soft. It requires almost no force to push it it in. (almost same force required as the accelerator pedal will push the clutch pedal all the way)
and rpms in 5th seem to be wrong. at 50mph I am going 3000 rpm..
what could be wrong? do I need a new clutch? I dont seem to notice any slipping or maybe I dont know what a slipping clutch even feels like. I'm a noob. :?
Thanks
PostPosted: Thu Nov 22, 2007 11:35 pm
Has the clutch always 'felt' like that, or is it a recent development?
PostPosted: Thu Nov 22, 2007 11:43 pm
I wouldnt know, since I just bought this car. Its a 91 vert. In my other 91 vert, the clutch is firm. But on this one, it goes down with minimal force. The clutch pedal on this feels like the gas pedal. I dont know... is this normal ? or maybe the my other vert which I am comparing it to, has a clutch that is too firm?
PostPosted: Fri Nov 23, 2007 2:51 am
If you can kill the engine by letting out on the clutch quickly in first, and not giving it any gas, then probably you are fine.
A clutch may seem soft or hard, depending on its pressure plate, whether there is grease in the cable, and the spring which retracts your clutch arm inside the bell housing.
You can see that second spring in figure 53 Here:
and if it's not hooked up right (v unusual) you would wear out your throw-out bearing quickly.
Another spring that should be here, but is either difficult to see or missing
is not so critical.
On these pages are a complete posting of what a trans should look like:
http://www.teamswift.net/album_cat.php? ... &start=120
If your transmission has a different gear ratio than your other convertible, it would explain the 3000 rpm at 50 mph.
Someone could have put that trans in, was unhappy w it's gear ratio, and so unloaded it to you or the person you bought it from. Does it make any unusual noises that make you think the trans is going out? Again, if you can kill the engine by popping the clutch at idle, your clutch probably isn't slipping and doesn't need to be replaced.
PostPosted: Fri Nov 23, 2007 8:02 am
thanks for the info, Phil N Ed... I think it might just be the pressure plate which is making the clutch pedal feel so soft.
I did the test of letting the clutch go in first gear, and yes, the car jerked for a second and the engine shut off.
but I dont understand the mph/rpm thing. Both my cars are same 91 metro vert. I dont understand why transmission would be different. I try to find some kind of number or identification to make sure both are the same trans...
Would someone happen to the the normal rpms at around 55-60mph ?
In one vert, I have 58mph/3000rpm, and in the other vert I get 50mph/3000rpm. For the rest of the gears the rpm's/mph are the same, but only I notce that 5th is a little different.
thanks
PostPosted: Fri Nov 23, 2007 2:06 pm
Read the thread on 'gear ratios'. That might help.
Also check to see they have the same height tires.
PostPosted: Fri Nov 23, 2007 9:19 pm
Here's a quick and easy check to see if your clutch is slipping - it's easier if you have a tachometer.
Get the car onto a flat or slightly sloping road (uphill) and with it in fourth at perhaps 40 mph or so, floor the throttle and then depress & release the clutch - you should see the tach needle kickup and rapidly drop back - or hear the engine rpms do the same thing - pay attention to what happens when you release the clutch, if the rpms do not stabilize within a matter of seconds, the clutch is slipping, and the longer it takes to stabilize the worse the slip.
PostPosted: Fri Nov 23, 2007 9:50 pm
thanks.. I will try that, and post back results.
PostPosted: Wed Nov 28, 2007 1:40 am
Took my GTi out tonight, and looked closely at the tach.
At 3000 RPMs in 5th gear, I am doing 54 mph.
Perhaps what you describe is normal. Maybe you simply have two similar cars with different gear ratios.
Hope this helps...
PostPosted: Wed Dec 05, 2007 9:10 pm
ok, the clutch is fine, and turns out that on my other vert that i though was normal, is actually too stiff.
and about the weird rpm, "bigbear1969" told me that my other vert may just have a transmission from a hatch in it. So I guess they were different gear ratios all along.
all this time I had a vert with a hatch transmission, and I thought it was a vert tranny and it was powerful, now that I have a vert with a vert tranny, I know what a real vert transmission power feels like. Its nice.
:D
I dont know about the mpg's though, I will find out.
PostPosted: Sat Jan 05, 2008 2:04 pm
Its weird.... But I think the different speeds were because there might be something wrong with my speedometer. I have noticed that even when I going the speed limit... I am always going faster than all the other cars.. And the needle of the speedometer also vibrates a little, and isnt smooth and soft looking like the one in my other car.
I guess I will have to use a gps to check the speed to make sure that my speedometer is working right or not... Could a speedometer ever go bad and show speed like off about 5 or 10 mph?
PostPosted: Tue Jan 08, 2008 9:06 pm
ok I have confirmed that my speedometer does not work right. It shows me as going 7mph slower than I actually am. So I guess the whole transmission & mph vs rpm thing was fine all along... its just my speedometer is inacurate alot...
I know its not because of my tires because they are stock size.
how I checked the accuracy of my speedometer? I drove next to a honda civic hybrid with those digital speedometers, and drove the same speed, and looked over at thier dash to compare to my speed. When thiers showed 67mph, mine showed 60mph... :lol:
PostPosted: Tue Jan 08, 2008 9:58 pm
And you ASSUMED that theirs was accurate.
Borrow a GPS from a friend and check yours - with stock wheels & tires there is no reason for it to be 11% off
PostPosted: Tue Jan 08, 2008 10:43 pm
Mama Said Knock You Out!
Your trans could have previously been changed also, don't forget to take that into consideration.
TGstring wrote:
sooooo clean it's duuuuurrty.
PostPosted: Tue Jan 08, 2008 10:56 pm
I assumed because it was a new civic,,, but anyway I will borrow/buy a gps and check it and post results..
thanks
PostPosted: Wed Jan 09, 2008 8:37 pm
is not so critical.
I though I had done this before - and just realised I never did
There is no clutch related spring in this area - it's not that it's missing or difficult to see - there isn't supposed to be one.
PostPosted: Wed Jan 09, 2008 10:58 pm
fordem wrote:
is not so critical.
Gentlemen, gentlemen...we are talking about a non-critical spring!!!
The information that I gave the Texan was correct.
The reference for my original statement was from memory. (Thinking back to the times I've adjusted clutches here in the U.S.)
But for those of you with left hand drives, maybe this is how it might look...
and for those of you with right hand drives:
Apologies to those of you who are not supposed to have this spring. It is barely visible below the "1" in the drawings above.
PostPosted: Thu Jan 10, 2008 10:06 am
I see the spring you refer to in those drawings - it's not on my car, never has been, and it's also not in my FSM - perhaps this varies from one year to another.
PostPosted: Thu Jan 10, 2008 11:27 am
I thank and excuse the gentleman from Guyana.
PostPosted: Thu Jan 10, 2008 3:47 pm
so I checked the speedo using my GPS and its about 6mph off. About 10% I think.. If I had different tire size, I would think the rpms would be affected also with speed, but they seem normal.
Here is a youtube video so you guys can see
http://youtube.com/watch?v=yvTUm6Zp-tQ
