It is currently Thu Oct 19, 2017 5:08 am
 Post subject: LSD advice needed
PostPosted: Tue Apr 12, 2011 10:36 am
Hello everyone. New member, long time lurker.
I'm working on an electric sports racer that I want to use for autocross racing.
I'm using a rear mounted 89 Swift GTi transmission mated to an electric motor. Here is a link to my build log http://www.szott.com/zot2/zot2.html
Since the motor puts out 140 ft-lb of torque from 0 to 5,000 rpm, I am getting a lot of (one) wheel spin on accelleration. I need an LSD.
I've searched this forum and found a lot of info on LSDs but most of it is not very current.
What I'm looking for, in order of preference, is 1) torsen type, 2) clutch type, or as a last resort, 3) phantom grip.
I'd appreciate any suggestions, advice and links to current suppliers. (I know where I can get the phantom grip)
I have access to a machine shop so I would consider modifying to fit if I can't get something off the shelf.
Thanks in advance.
Jan
Ontario, Canada
 Post subject: Re: LSD advice needed
PostPosted: Tue Apr 12, 2011 11:00 pm
http://www.modenaengineering.com.au/ they make torsen diff for GTi. Looking at around AUD1300 new.
ImageET 13.138 at 120.2mph
PostPosted: Wed Apr 13, 2011 6:38 am
I already spoke to Modena. They don't make them any more. They can do a special order but they need an order for at least 10 units.. They quoted me $1100AUD each if I order 10.
PostPosted: Wed Apr 13, 2011 2:00 pm
Why are you using a Swift transmission? A Civic transmission is stronger and the LSD should be cheaper. You could probably get a JDM Honda Trans with a factory LSD for less than the Swift LSD by itself.
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
PostPosted: Wed Apr 13, 2011 3:52 pm
:werd:
I love what you have done with your car(I read the whole build), and I love swifts, but our trannies are utter garbage. Looks like it would be a ton of work to un-do all the stuff you have done to make the Swift stuff work in your Lotus clone, but maybe a 1.6 swift trans would be a way for you to not have to re-engineer too much stuff and end up with a tranny that will better take the mountain of instant torque your elect motor will be able to put out.
With just a turbo setup on my GT I'm having to go into the trans AGAIN (bearings / breaking diff pin through the case, etc.) for the 3d time.
You would still have the LSD issue though, I don't think anyone makes a LSD for the 1.6.... so your machine shop you have access to would maybe have to modify one from an existing car.
PostPosted: Thu Apr 14, 2011 6:02 pm
airwerks wrote:
:werd:
Maybe I should have used another doner but I've always had a love for the Swift ever since I owned a 91GT. I never had one problem during the 10 years I had it until the frame rusted out and I had to tearfully take it to the bone yard.
Yes, I don't mind modifying one but I have no idea as to what is even close to the right size. Suggestions are welcome.
PostPosted: Fri Apr 15, 2011 5:00 am
Hi, have just read your website, VERY nice job, am building a rwd two seater myself (slowly and it's an ICE),Aeriel Atom style, will be using a swift box in the back, will probably use the 1600 sedan fwd box as it is cable shift and hydraulic clutch, the top two bolts holes on the box require modifying and you will need to use the 1600 flywheel and clutch if you wanted to use it with your current motor adapter, also the intermediate shaft mount is just slightly different, personally if you already have the 'little' g13b box then keep using it, if you break it then the g16 box is the closest heavy duty replacement, pm CodyP76 on this site as he fixes and parts out hundreds of suzuki's and it likely to have one.
Torsen style is the way to go for your car, the sound of clicking lsd plates would be really annoying when there is so little other noise, there is an Italian company that makes LSD's for Mk2/3 suzuki swifts, just rebuilt my pc(HD did not survive earthquake) and lost all my bookmarks so I can't find a link for them sorry, Cusco also make/made torsen style lsd's as well, Gripper in the UK make clutch type and are probably the best LSD's around, couple of guys on this site running them, otherwise sign up to redlinegti (sister site to this and mostly aussie based) and ask around for a 2nd hand Mondena lsd, they do come up quite often although resale is usually 85% of new price.
Omarcitoh in Spain will know of other lsd suppliers, he's tried (and broken) quite a few of them :lol:
P.S Honda is a pita, spins the wrong way :thwack:
PostPosted: Fri Apr 15, 2011 7:19 am
:o
Dattman you refer to this http://www.bacciromano.com/index.php?p= ... =70&mar=13 ? If yes...They are not cheap and lsd is plate type...
PostPosted: Fri Apr 15, 2011 4:23 pm
Thanks Omar, yes that was the site, couldn't remember if they made a torsen or plate type lsd, yes they are a bit expensive, strange when you consider thier close ratio gear kit is actually quite good value.
PostPosted: Fri Apr 15, 2011 6:11 pm
In Hungary you can buy used LSD at very low price(cca 400-600 EUR... Bacci, Quaife)... major problem for all of us is their language... and many of them don't speak any other language than hungarian... I'm their neighbour(Croatia) and don't understand a thing... LOL... :huh: :huh: :huh:
Bacci LSD is ok, because you can buy all the spare parts that you need(and if needed)...
PostPosted: Tue Apr 19, 2011 12:31 pm
im running a gripper in my gti, its a combo of locking and clutch plates ivdriven a similar car to a swift with a factory cusco type and tbh i didnt like it that much
with the gripper the lock is a bit more harsh than the cusco type diffs but you probabally wont notice as much in rwd than you would in fwd
the only down side is they are quite expencive now, it was £500 when i got mine a good 5 years ago
gary
Have a look, you know you want to!
Swift. http://m.flickr.com/#/photos/11473969@N02/
Evo. http://m.flickr.com/#/photos/100754123@N04/
PostPosted: Tue Jul 12, 2011 5:30 am
Hello Everybody,
I'm a newbie here.
I can produce and sell Helical/Torsen LSD-s for suzuki swift.
This "no brand" torsens made in absolutly superb quality.
No wearing parts, simple fit, replace OEM diff.
Dramatically improve handling and cornering speed.
I'm using the same type in my rallysprint car.
If you have any question please do not hesitate to write: wokum@freemail.hu
I will send photos, specs on request.
I'm living in Hungary, and sorry my english is poor as our croatian friend said. :lol: :lol:
It was an used one (sold to down under last week):
PostPosted: Tue Jul 12, 2011 7:12 am
i have 3 set used cusco LSD for gti. selling for 700usd + shipping each. Drop me PM if interested. Its clutch type
http://www.flickr.com/photos/43384907@N05/
PostPosted: Tue Jul 19, 2011 9:03 am
hailings all, recently got myself a gti and looking at ways to improve on its handling and power potential. will be boosting it and use it for weekend circuit racing at dover, here in jamaica. this is a colleague of mine, no lsd means corner exits are plagued with wheelspin. http://www.youtube.com/watch?v=31RWnJLvI5k
http://www.youtube.com/user/byles12?ble ... g3njHkjsDw
would definately be interested in getting a lsd and if possible, convert to 4wd. those prices seem a bit on the steep side especially with a conversion rate of 1usd = 87JA.
i know quite a few of my colleagues here who would also be interested so maybe we could make a bulk order of the price is good.
wish i had a car like runbag, wonder if he would help me build 1?
PostPosted: Fri Aug 05, 2011 1:18 am
Balli, the quality is really excellent and the metal is damn tough, but the sun gears are in the opposite orientation to normal - and can't be swapped easily because they have different outer diameters. When power is applied they are forced inwards instead of outwards. Diff still works but lots of stress in put in the thin star shaped tube that holds the belleville washers. Unless this is deliberate for some reason, it is opposite to the quaife design that pushes them outwards towards the casing.
Please have a good look yourself and see if you know what I am talking about. There is one good link below.
http://forums.clubrsx.com/showthread.php?t=520556
balli wrote:
Hello Everybody,
I'm a newbie here.
1989 Mk2 Gti
1968 FIAT 124 Sport
PostPosted: Sat Sep 03, 2011 9:28 pm
Is it me or is the gearkit from those guys helical cut? :huh:
PostPosted: Sun Sep 04, 2011 2:59 am
Yep, and the problem with that is???
PostPosted: Sun Sep 04, 2011 4:09 am
:o No problem....This is actually a great thing :D
PostPosted: Sun Sep 04, 2011 4:30 am
It's good if you want to do the sleeper thing, they are more expensive as they need to be ground and helical gears do put a lot of pressure on the casing.
I have just bought a 2nd hand Bacci plate type LSD and the quality seems very good, haven't got it in the car yet.
PostPosted: Thu Jul 12, 2012 9:30 am
Make sure you have the half-shafts, or whatever they are called, that goes into the pumpkin as well, It is uses cone clutches rather than helical gears. But the shift window is definitely much shorter compared to stock.
Users browsing this forum: Bing [Bot] and 4 guests
