It is currently Wed Oct 18, 2017 5:24 am
 Post subject: 1989 suzuki swift gti
PostPosted: Sat Oct 22, 2011 10:08 pm
new to this but I need help :) my transmission blew out. A gear broke off and my trany is cracked I need to know what other trans will fit into my car. Can I got to pick a paet and get a geo metro trany? Any help would be great
PostPosted: Sat Oct 22, 2011 10:15 pm
Yep.
PostPosted: Sun Oct 23, 2011 3:28 pm
As Phil and Ed said "Yep"
But since your at it anyway, Why not make a minor performance upgrade, By putting in a tranny with a slightly more performance oriented gear ratio from a 90-93 convertible? :) (You will lose 1-2 MPG +/- :( )
I jumped on "CAR-PART.COM" (Which I consider the greatest resource that the internet has yet to provide :D )(Don't Forget the "-" {DASH} in the middle or you end up at A JC WHITNEY Site :-P :-P ) and I found 2 in California. 1) at Concord auto dismantlers in Concord Ca. (1-925-685-7706) and #2) at Standard Auto Recycling in Chula Vista Ca. 1 -619-426-1166. This is not an endorsement of either organization, I Just thought I could do a little leg work for you.
Good Luck, Hope your back on the road soon,Jonathan
Current stable:
PostPosted: Sun Oct 23, 2011 3:57 pm
He'll probably go about 3 miles to the Pick A Part on 6th.
Or, he could head to an Ecology in Fontana.
Southern California has some pretty decent yards.
The nearest one you mentioned was a 250 mile round trip.
The other? Almost 1,000 miles.
California is a big place. It might not get as hot as North Florida :roll: but there are plenty of Metros in the yards.
If he gets a Metro tranny, he'll probably still have his 4.10, like stock.
We have a 4.39 in our white '89:
because the previous owner tried a 3.79 and shredded it
and 5th gear.
:shock: :shock: :shock:
So your advice to try a 4.39 is pretty good.
I'm thinking this guy is a 'one shot' fellow, who won't be posting much on Teamswift.
Maybe he isn't thinking as far ahead as you.
8)
PostPosted: Mon Oct 24, 2011 10:09 pm
Good Point Phil and Ed, on the potential one post thought, But with a little encouragement, and a bite from the performance "BUG" we may have another convert over to the "DARK SIDE" :lol: :lol: This is how it starts. :) :)
Current stable:
PostPosted: Mon Oct 24, 2011 11:08 pm
You are right.
Knowing Highland like I do, it would certainly be a surprise.
PostPosted: Tue Oct 25, 2011 12:30 pm
yards are big here in south cali
i mostly head all the way to chula vista, wish i didnt live in eastcounty. chula is kinda far
why i haven't got a dirver side window yet. too far :(
PostPosted: Wed Oct 26, 2011 11:21 pm
soo I coukd get a geo trans. Sorry guys I'm not that smart at this 4.39 ratio. One of those gears it's a small one it says 1 and 3 a tooth of the gears that blew out of my trans. I want the same acceleration what would you doo phill_ ed.
PostPosted: Tue Nov 08, 2011 9:12 pm
By going to the 4.39 final drive ratio(which I believe were found only in the 5Speed Convertibles.) You will pick up a slight bump in acceleration over the (Numerically) Lower stock ratio.This will cause a slightly lower top speed (3-4 MPH) and slightly higher Gas consumption due to Higher RPM's (revs) at highway speed (I'd Estimate 1-2 mpg), But that little extra bump in acceleration from the stoplight, and its incumbent "grin factor" makes it a worthy upgrade at little or no increased cost over what you would pay for a stock GTI unit or even A stock regular 5peed Metro unit. I hope this Helps. Best wishes,Jonathan
Current stable:
PostPosted: Thu Nov 10, 2011 9:10 pm
The 4.39 is in all the 1.0 cars that had 13'' tires. That means any 95-01 3 cyl Metro plus the verts.
Ken.....
PostPosted: Thu Dec 22, 2011 8:53 pm
Hi bro! Were you able to fix this problem? What trans did fit your car? I'm also having this same problem, my trans also blew out yesterday.
Norman Summerville
:::NEXT PROJECT::: Suzuki Engine Parts Mods
:::NEXT BUY::: Suzuki Parts, Suzuki Accessories
PostPosted: Mon Dec 26, 2011 1:53 pm
Hey! man i put in a metro geo trans. car has been running good with it too.
