It is currently Wed Oct 18, 2017 5:58 pm
 Post subject: Trans replacement
PostPosted: Wed Jan 25, 2012 8:43 am
Someone mentioned that there is another transmission that can be retro fitted to the geo. Hyundai trans?
Fainya
 Post subject: Re: Trans replacement
PostPosted: Wed Jan 25, 2012 1:50 pm
yes it has been done but is a involved swap. not much if anything is bolt on. im doing this swap but now im just preping the bay for it
1990 swift GL Twincam swap
PostPosted: Wed Jan 25, 2012 2:16 pm
please update with your progress EngineWhisperer :P
PostPosted: Wed Jan 25, 2012 10:33 pm
i will for sure. I am planning on making a full write up of the swap as info is scattered at best.
PostPosted: Sun Jan 29, 2012 7:04 pm
What is the transmission out of? Make? model?
How many forward gears?
Final drive ratio of worm and ring gear?
I assume you will be using a geo flywheel, and pressure plate?
I also assume that you will need geo axles with other car CV joints at the new trans?
Clutch cable or hydrolic clutch?
Will a shifter have to be fabricated? I assume yes?
Will you be using a geo driver side mount with an adaptor plate?
I am tired of an automatic car. I can not seem to find a geo trans with less then 200,000 on it. This worries me as to gear fatigue.
Fainya
PostPosted: Sun Jan 29, 2012 10:39 pm
you can just get a used trans and install a transmission repair kit, as long as the gear teeth are okay (usually are) it will make the transmission 'as new'
PostPosted: Fri Feb 03, 2012 10:23 am
You have to have a transmission first. This is a project for my automatic car to convert it to a standard.
Fainya
