It is currently Sun Jan 21, 2018 3:52 am
PostPosted: Sat Mar 10, 2012 1:37 pm
I have a automatic trans out of a 1991 metro with the torque converter. I will be making a special mounting plate to mount an engine other than a metro 3 cyl on it for a special vehicle project. This machine will use the transmission and only the trnasmission out of this geo... no engine or computer.
My question is will the transmission (complete with hoses and cooler (radiator) work as it would in the car given the computer that controlls the engine is not hooked up to it? In other words will the trans run/shift normaly with another engine in a different vehicle or does it need the CPU / brain/ computer out of the 1991 Geo? Thanks in advance.
PostPosted: Sat Mar 10, 2012 1:43 pm
Does it have a wiring harness coming out of it for electric shift solenoids?
A Powerglide 2 speed transmission would work properly if you want a simple set up.
You'd just have to hook up one vacuum line and if you want it to downshift, some downshift linkage.
PostPosted: Sun Mar 11, 2012 4:07 pm
If I'm not mistaken, these automatic transmissions are controlled by their own "electronic brain" that communicates with the engine ECM. I believe this transmission controller (which is located under the dash to the right of the instrument cluster) tells the tranny when to shift.
PostPosted: Sun Mar 11, 2012 5:34 pm
Welcome to Teamswift, hobsickle. Cool name.
There's a famous High School Biology Teacher by that name in Michigan!
Gotta have this:
along with a lot of other inputs for it to shift correctly in Lake Placid.
Like hobsickle said, the answer to your question is 'no' if you have the transmission with the wires coming out of it and the two electric shift solenoids inside next to the throttle body. What does your automatic transmission look like?
PostPosted: Fri Mar 16, 2012 9:41 pm
In the spirit of
"It is a bigger man who will admit when he is wrong..."
or
"Time to eat some Humble Pie"
...the picture I posted above is the ECM (not the TCM) up to the left of the instrument cluster.
If you want to find the TCM in an '89 on, you'll be looking to the right of the steering column:
(this is a '93 convertible, for example)
You'll need both, plus the instrument cluster and wiring to get it to shift right, along with the sensors, IIRC.
PostPosted: Sat Mar 24, 2012 10:27 pm
There is a 2 wire harness that comes off the back of the transmission.(they use the transmission for the ground) This is for your 1-2, and 2-3 shift solenoids. All you need is switchable power(+12 volts) to each wire to get your trans to shift. Make sure you have a ground strap to your transmission or the circuit will try and ground out through your CV joints and will destroy the CV joints and the final drive bearings in about 10,000 miles.
Fainya
