It is currently Sat Jan 20, 2018 4:23 pm
 Post subject: transmission help needed
PostPosted: Wed Mar 28, 2012 9:46 am
Ok so I need to replace the trans on my 89 gti asap I found a few shops near me that carry geo metro transmissions
But being a noob to the swift world I am unsure of what year geo would fit direct bolt on.
Help me out! Lol thanks
PostPosted: Wed Mar 28, 2012 10:12 am
Most say that the 4.39 Metro tranny that is in the verts and 95 and up 3 cyl cars is the way to go. It is a little lower geared and helps with that big jump between first and second that you have now but comes with a lighter duty ring gear that won't take the abuse of high horsepower as well. Also they don't have a place to bolt that extra brace the is on the bottom of the gt tranny.
Ken....
PostPosted: Wed Mar 28, 2012 12:31 pm
Well I found a swift trans for a single cam motor ....would that work ?
PostPosted: Wed Mar 28, 2012 4:43 pm
Ha!
Yeah, it'll bolt up, but the gear ratio is 3.52.
Might not be as spirited to drive.
You are supposed to have the 4.10, and they suggested (above) a 4.39.
What you've found is going the other way.
PostPosted: Fri Mar 30, 2012 2:14 am
i kinda figured that, but i just need it to work....as long as its up and going im good with that lol
plus i imagine ill get a more mpg with the wider gear ratio
PostPosted: Fri Mar 30, 2012 5:40 am
Knowing the freeways like I do, I'd suggest you spend a little time looking for the other gear ratios.
The 3.52 is excellent on long trips, something you rarely will see in that car.
Do a 30 minute search of Teamswift and you'll find out what cars have the gear ratio you need.
Depending on how you drive, a 3.79 or 3.52 transmission will not last long.
Here is an example of someone mating a 3.79 to a GTi:
I don't expect you to know this as you are new to these cars.
A non GTI transmission will bolt up, except in one area.
You can have your box rebuilt or do it yourself.
We have taken a lot of time to post the techniques.
Perhaps the best compromise would be to find a 4.10 Metro transmission and swap the insides with your transmission case. Metros can be easily found at your local junkyards.
Then, you follow the DIY Split the Case thread.
