It is currently Mon Oct 16, 2017 8:51 pm
 Post subject: speedometer gears
PostPosted: Wed Jul 25, 2012 7:01 pm
After doing a 5speed conversion, I have a speedometer that is reading to low.
The gear is a white with 17 teeth, and a gear diameter of 0.500"
Does anyone have a gear with less teeth that is 0.5" in diameter?
What other options do I have to get the speedometer to read correctly?
Fainya
 Post subject: Re: speedometer gears
PostPosted: Mon Jul 30, 2012 8:48 pm
what size of tires do you have?
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Tue Jul 31, 2012 2:25 am
13" tires 155/80-13
A 16 tooth gear brings the speedometer back to right on.
Fainya
PostPosted: Thu Aug 02, 2012 5:48 am
it'S weird,,, the white speedo gear that i have was for 13" tires,
try the brown from a GT
but i don't know if you need to change the other gear in the tranny... you can check if so or if not,with the part numbers!?!
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Tue Aug 07, 2012 6:28 am
Did they ever make a 15 tooth gear for the 5 speed transmissions?
With the choice of 155/80-13" tires available getting harder to find, I was thinking of going to
175/70-13". THere is a much wider selection of tires available in this size.
155/80-13 is 21.7" diameter.
175/70-13 is 22.7" diameter.
A 15 tooth speedo gear should bring the speedometer closer to being accurate.
Fainya
