It is currently Thu Oct 19, 2017 7:07 pm
PostPosted: Tue Jul 31, 2012 5:07 pm
Hi guys, My 88 sprints clutch stopped disengaging today while I was on my lunch break, I had to rev match to shift :lol: .Ok, so as the title says I need to find a part of the clutch cable linkage. I do not have pictures, sorry, but I know where my problem is. There is a linkage piece that is attached to a splined "dowel" i guess thats all I can think of to call it. But this dowel comes out of the transmission and is responsible for moving the fork to hit the throwout bearing. Now the part that I need is the one clamped around that dowel and on the other end is attached to the clutch cable where the adjuster is. Its obviously stripped out and I have no idea what to call that part. Any help is appreciated. Thanks
1988 Chevy Sprint Turbo
Low and slow
PostPosted: Tue Jul 31, 2012 5:53 pm
Looks like it is the "clutch release fork lever" and this looks to be the right part but says its for a 1990 http://parts.nalleygmc.com/products/Che ... 63568.html . Does anyone know if this part is the same for an 88?
Low and slow
PostPosted: Tue Jul 31, 2012 11:33 pm
The newer Suzuki's used a shaft with a larger spline, so the newer one is not a drop in, but the newer shaft, and lever can be made to fit with custom bushings, and maybe a bit of easy machining....been a while since i did mine. The factory Mark 1 set-up is a bit weak for strong clutches.
