It is currently Thu Oct 19, 2017 4:38 pm
 Post subject: switch CV joint
PostPosted: Thu Oct 11, 2012 11:18 am
Hello,
My mk1 SA413 makes a clicking noise when turning. I'm pretty sure it is the CV joints.
Because the noise only happens in forward drive, i'm thinking in switching the joints left-to-right and right-to-left in order to change their rotation, and therefore the noise will only happen in reverse drive.
Did anyone ever tried this on a mk1? Does it work?
Thanks,
Bruno Pires
Swift 1.3 GS 1986
 Post subject: Re: switch CV joint
PostPosted: Thu Oct 11, 2012 4:25 pm
The two cv joints are different lengths. You can't switch them. The left side is short and the right is long.
PostPosted: Fri Oct 12, 2012 4:34 am
Isn't it possible to dis-attach the semi-axle (shaft) from the joint it self?
Swift 1.3 GS 1986
PostPosted: Fri Oct 12, 2012 8:17 am
it is possible but if your going thru all the hassle just put a new joint on the shaft and be done
