It is currently Sat Oct 21, 2017 9:11 am
 Post subject: 93 swift model trans
PostPosted: Sun Jan 13, 2013 1:47 am
what model trans does the 93 swift GA 5 speed have?
Switch to the slow lane when your going too fast
 Post subject: Re: 93 swift model trans
PostPosted: Sun Jan 13, 2013 3:35 am
Moved.
Please post in the correct forum.
The answer is coincidentally at the top of this forum where it says "look here first".
PostPosted: Sun Jan 13, 2013 9:29 am
You didn't specify automatic or 5 speed.
We have the 5 speed with the 3.52 final drive.
It is a bit difficult to get used to if you've never driven a stick shift before.
However, if you are experienced, it is a perfect match for the SOHC 1.3L for gas mileage.
The other gear ratios available (4.39, 4.10) are easier to learn with if you are inexperienced, but your engine will run faster at highway speeds.
...and welcome to Teamswift
PostPosted: Sun Jan 13, 2013 4:26 pm
PostPosted: Sun Jan 13, 2013 7:56 pm
suprf1y wrote:
Busted!
:oops: :oops:
Fair and square!
:lol:
Users browsing this forum: Yahoo [Bot] and 7 guests
