It is currently Thu Oct 19, 2017 2:53 pm
 Post subject: Trans, Engine Gap
PostPosted: Wed Feb 20, 2013 12:36 am
In the process of installing new trans and clutch into 1997 metro 1.0 and also converting to 1.3 clutch/flywheel. I am having trouble closing the gap, approx 1/2" between trans and engine, rechecked alignment with dowel and seems to be good. Any tips on doing this and what could the problem be.
 Post subject: Re: Trans, Engine Gap
PostPosted: Wed Feb 20, 2013 2:59 am
did you get the clutch disk in backwards?
PostPosted: Wed Feb 20, 2013 6:10 pm
did you jam the throwout bearing by pulling on the clutch arm?
1994 Geo Metro Turbo
PostPosted: Wed Feb 20, 2013 11:37 pm
one time i didnt make sure the splines where through the clutch disk fine and ended up jamming them up, needed a new clutch disk.
PostPosted: Thu Feb 21, 2013 12:26 am
Good points fellows, thanks but I have triple checked everything, unless the clutch is mislabeled, I put the side marked F/W side facing the flywheel. Have not had chance to go back out and work on it, cause of work and too cold outside.
PostPosted: Mon Feb 25, 2013 6:06 pm
One side will be "flatter" than the other. that side goes to the flywheel
