It is currently Sun Jan 21, 2018 9:52 am
PostPosted: Wed Mar 13, 2013 9:01 am
Does anyone know the model # for my 94 Swift GT 5 speed? Is it an MV3?
I need to do a clutch and would like to order the CV axle/shaft differential seals in case I mess them up.
It appears that the MV2 transmission seals are readily available, but I suspect this is not the transmission I have?
Thanks for the help in advance!
PostPosted: Wed Mar 13, 2013 2:04 pm
other than internal hard parts (gears) the transmissions are the same 89+ when it comes to seals. what seals are you looking for? we had trouble at my shop finding the rh axle seal but i was able to pull a number off my own car and got the correct one for a 92 metro
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Fri Mar 15, 2013 9:14 am
It is the CV axle/shaft differential seals right and left that I may need. Many of the on-line suppliers list these seals as you say being all the same for all models and years However, it appears there are design and thickness differences between seals that makes me think there may be seal differences between the GT trans and small motor 1.0 L trans. Perhaps they will all work?
