It is currently Sat Oct 21, 2017 4:39 am
PostPosted: Mon Jul 08, 2013 9:15 pm
what trannys will work in my 89 swift gti. I'm thinking of going to the junk yard and pulling a tranny out of a geo until I can rebuild mine. Is this a bad Idea?
PostPosted: Tue Jul 09, 2013 12:21 am
i dont think that it is bad idea at all but make sure that it gets well within your budget.
PostPosted: Thu Jul 11, 2013 6:21 am
When you say going out, is it noisy? Or jumping out of gear? Or hard to shift into gears?
Fainya
PostPosted: Thu Jul 11, 2013 12:56 pm
Pulling from a geo isn't a bad idea. Anything from 89-01 will work. If you want exactly the same ratios, choose a 89-94 transmission from behind a 3cyl(4:10 final drive), if you want a bit of extra pickup, grab a 95-01 3cyl transmission(4.39 final drive), all convertibles share this final drive, if you happen to come across one. 4cyl models will all have lower (numerically) ratios, so you will lose some pickup and have a lower highway cruise rpm. Used trannies are a bit of a gamble on these cars, but there are good ones to be had still. If it shifts into second from third, you're golden! That's the weak point, and it's basically gotta go in to know if it's good. With a spare, even if the spare isn't the best, you will have time to get your gt trans repaired properly, rebuilt, whatever you choose.
PostPosted: Thu Jul 11, 2013 7:27 pm
It is starting to make alot of noise in all gears and the noise only goes away in neutral
PostPosted: Sat Jul 13, 2013 9:52 am
i recommend fainya as a rebuilder for your transmission. :thumbsup:
