It is currently Sun Feb 25, 2018 10:52 pm
PostPosted: Sun Sep 08, 2013 11:29 pm
So... too much power + drag slicks = broken half shaft. is it possible to get anything stronger??
1998 Chevy Metro 2.6L Twin Turbo AWD
PostPosted: Mon Sep 09, 2013 3:47 am
Jump on redlinegti and pm dmwdave, I think he has had made stronger driveshafts made for the awd box
PostPosted: Mon Sep 09, 2013 1:09 pm
I'm running two 2WD boxes. One front one back.
PostPosted: Tue Sep 10, 2013 12:09 am
The GTI axles have stronger joints on them. That might be a good start.
PostPosted: Tue Sep 10, 2013 3:49 am
Only the outer cvs are slightly stronger and shaft is 1mm thicker, the weak inner cv's are the same, not much choice if you want to stick with the 'little' small framed swift/metro box, most people drag racing swap to the stronger large frame g16 fwd cable shift box or the awd box as they have a much bigger diff and larger inner cvs, dmwdave carries HD driveshafts for this box, if you have money to burn you could chance your luck with Suzukird.
