It is currently Sat Oct 21, 2017 11:27 am
PostPosted: Mon Sep 09, 2013 6:56 pm
i was cleaning in the bat cave, really! i was throwing stuff away and when i moved a pile of old magazines, papers, receipts, etc. i found something i have been looking for about 6 years.
before adam shut down occ racing (or more precisely, disappeared without a word :lol: ) he sent me a prototype transmission part for testing. this is a titanium alloy plate that holds the shaft bearings together at the outer ends, i believe for 5th gear. i think that adam told me that it was supposed to keep the shaft ends from spreading under the increased torque that a turbo applied to the gear box.
the conversation took place so many years ago that i can't remember the particulars but i recall him saying that the oem plate would deform under extreme conditions, actually stretching the steel plate. this alloy was supposed to maintain it's integrity. i think it fits under the stamped steel cover on the outer end of the transmission.
anyone recognize this?
PostPosted: Mon Sep 09, 2013 8:04 pm
Make love, not moderators
You are correct. It sits behind 5th gear and also holds the shim in place for the countershaft bearing.
PostPosted: Tue Sep 10, 2013 12:06 pm
I think I see rust in the second pic in the ID of the large holes..... meaning it's not titanium. Might be A572 or A514 if it was made from a stronger material......
PostPosted: Tue Sep 10, 2013 1:02 pm
If I stand upside down, it seems vaguely familiar :lol: :lol: :lol: :
The long ear fits into a slot on the shift shaft.
A blast from the past:
viewtopic.php?p=321659#p321659
Those 6 Phillips heads are rounded off, probably from being tightened after they became loose.
When you do a transmission, you should clean up those heads and use locktite.
If the phillips heads have oil in them, you might round them off when you tighten them.
When taking them off, make sure you spend the money on a good impact driver set.
Again, if the heads are clean, you probably won't round them off.
Once that plate comes loose, the two shafts may have some end play.
End play is worst at the end of the shaft and 5th gear is the first to go:
Nasty.
Next, the chips circulate through the gearbox and eventually tear everything else to heck and back.
PostPosted: Tue Sep 10, 2013 5:53 pm
i've used quite a number of titanium bolts in my last few engines, 2 turbo3 tricks and the red vert's twincam. i'm especially fond of using titanium bolts to mount aluminum under drive pulleys with the thought being that every little bit of rotating mass i reasonably shave off the crank assembly is a good thing. i'm pretty sure that this is done from a piece of aerospace billet alloy.
what you are seeing in the pic is the red light from my digital camera as it does it's auto focus and flash adjustment thing.
PostPosted: Thu Sep 12, 2013 10:57 pm
[quote="t3 ragtop"]i was cleaning in the bat cave, really! i was throwing stuff away and when i moved a pile of old magazines, papers, receipts, etc. i found something i have been looking for about 6 years.
Yes I do! I have one installed in my transmission. It is a hardned steel ? Adam told me the reason to use it. and I saw picture of the problem, that it held the shafts in place so that the force of the helical gear is held in place.
I believe it is true as I have not had an issue since, but I am a little shy on pounding the transmission.
I remember Adam saying someone ran up to 270 HP through a GT transmission.
Anyway, the idea is not new as I saw Honda's do the same thing. "Transmission support" they would remove fifth gears as a sacrifice. Because theirs was much more rugged.
90 Swift GT - GT-BBT25 turbo Red - For Sale
99 MX-5 10th AE Saphire Blue
2011 Infiniti G37x
2010 Equator White
2000 Solara convert
PostPosted: Fri Sep 13, 2013 6:58 am
bingo! there's more than one out there. :wink:
PostPosted: Sat Sep 14, 2013 8:09 am
This is what I saw for comparison- maybe remove fifth gear all together?
Phantom Grip Transmission Cradle
Save time and money with the Phantom Grip Transmission Cradle. Improve your transmission's reliability with this proven product that has been developed and tested in the highest horsepower Honda applications since 2003. Guaranteed to increase transmission life by more than 100% and proven to handle up to 950hp. The transmission cradle replaces the fifth gear in your Honda B-Series transmission by cradling both main shafts together. This helps keep the gears from walking away from each other, reducing potential failure. BUY YOURS TODAY!
File comment: Cradle
2011 Infiniti G37x
2010 Equator White
2000 Solara convert
PostPosted: Sat Sep 14, 2013 4:49 pm
i don't plan on trying to deal with 940 hp or any of that - i'm just trying to make sure that my machine will hang together up to a couple hundred hp just in case i feel froggy one day. =)
i've had this part lost in my basement for something on the order of 7 or 8 years. i feel the need to use it on one of my cars. :wink:
PostPosted: Sat Sep 14, 2013 7:30 pm
Well the good news then is that you don't need to completely disassemble the trans to install it.. Just remove the black cover and remove fifth gear to gain access to it.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
