It is currently Wed Oct 18, 2017 3:31 pm
PostPosted: Mon Jan 27, 2014 2:39 pm
Hi! My first post here! I need some advice on our transaxle.
My 1991 Geo Metro 1.0 L Automatic was pouring transmission oil OUT of the bell housing/input seal.
We opened the transaxle pan and it was clean! The fluid was burned, but no parts or shavings inside the pan.
We pulled the transaxle and the torque converter.
- what looks like a race or bearing came out with the torque converter. The bearing or whatever shows signs of spinning, is steel on the outside and has copper on the inside with dimples, about 1-1/4" in diameter, and fit snugly onto torque converter shaft.
-the first time we took it all out, that piece fit snugly and came out with the torque converter.
We replaced the seal, reassembled all, the engine started well, warmed up and then started spewing trans oil again.
Disassemble again.
-This time when we pulled the torque converter, that ring stayed behind *behind* the seal (inside with the tranny) and we had to fish it out.
ANY ideas what that piece is? part no.?
AND -- where can we get an exploded diagram and if available, service procedure, for the transaxle? Not finding it online!
PostPosted: Mon Jan 27, 2014 4:27 pm
Even the FSM doesn't show much for that seal on the input shaft. Could you post a picture or 2.
PostPosted: Mon Jan 27, 2014 8:58 pm
you need to replace the front pump bushing
PostPosted: Tue Jan 28, 2014 2:07 am
I did find this diagram.
