It is currently Mon Feb 19, 2018 4:54 pm
PostPosted: Mon Feb 17, 2014 4:38 pm
Cheaper than lsd.
PostPosted: Fri Mar 14, 2014 3:15 pm
is this the device that severely increases spider gear preload to give a lsd effect?
PostPosted: Sat Mar 15, 2014 12:53 am
it work same way than plated/clutch style lsd but is not even close to the real lsd effect.. phantomgrip have them for about 300eur if i remember right..
imo only good for street use but since there is lot's of friction between diff and this "lsd" it probably wear fast and it's a lot of work to open gearbox and change it.. + spare parts cost + often oil change because of metalic/alu/.. in oil..
i bought helical (torsen/quaife/truetrac) lsd from guy from hungary (new for 600eur) and there is no wear parts + work just great!
PostPosted: Fri Mar 21, 2014 10:25 am
who can explain how it work? I don't understand... :?: :shock:
PostPosted: Fri Mar 21, 2014 6:05 pm
you know how open diff work? well, there are 4 springs between those plates which keep spider gears from spinning..
check youtube.. open diff, clutch/plated style LSD, phantom grip lsd, helical LSD,...
PostPosted: Fri Mar 21, 2014 7:19 pm
Basically you're grinding 2 pieces of steel against the spider gears in an attempt to slow down the difference in speed between the two wheels.
PostPosted: Fri Mar 21, 2014 7:54 pm
will it be found if lift the wheel off & spin the front wheels?
if I do this in a race won't allowed to use LSD?
PostPosted: Sat Mar 22, 2014 4:49 pm
yes if you lift one wheel and try to spin it this will prevent it from spinning.. until enoug force is applied..
but if there is no LSD allowed it will be clearly seen in driving difference.. you can't fool others with LSD, shorter gearbox or more powerfull engine.. all those things can be seen while you drive.. (shorter box or more powerfull engine can be seen in faster shifting to higher gear than others, lsd can be seen by going around corners in different way,..)
PostPosted: Sat Mar 22, 2014 9:02 pm
I mean if I use this set, if I jack the car up to lift 2 front wheels off the ground and spin the wheel, what would it be?
PostPosted: Sat Mar 22, 2014 10:02 pm
if you have both front wheels in air and you spin one, both will spin..
PostPosted: Sun Apr 13, 2014 11:33 pm
In the past i had sold 2 of these to a customer. They suck, they dont work. you are wasting your money. but thats just my opinion
AutoPerformaceUSA.com
PostPosted: Mon Apr 14, 2014 9:59 am
they work just not even close to real LSD..
it's waste of money to give 300eur for this if you can get nice torsen or plated LSD from Balli for around 600eur...
