It is currently Thu Oct 19, 2017 6:10 am
PostPosted: Sat Jun 28, 2014 5:41 pm
I have recently changed my gearbox over and for some reason it is hard to
Select 2nd gear and slips out if I don't hold it in, I'm new to this and basically
Have no knowledge on what is going on. its a 94 gti
Any advice will be much appreciated can't wait to here from you.
8k is the all vraaapp vraaaaapppp brraaaaaaap
PostPosted: Sun Jun 29, 2014 12:55 am
viewtopic.php?f=9&t=14856&start=25#p411326
Check page 7A-6. I suspect it's the third diagnosis.
PostPosted: Sun Jun 29, 2014 2:08 am
Thankyou will look cheers
PostPosted: Sun Jun 29, 2014 2:50 am
More likely the 5th one, 'worn chamfered tooth on sleeve or gear', translated that means the little engagement teeth on the side of the gear and on the sliding part of the syncroniser hub are worn out, when they round off they won't stay engaged, the low speed syncroniser hub is probably the most expensive part in the whole box and hardest to source.
If it's nothing obvious like a broken engine mount or incorrectly installed/bent shift rod then you are probably looking at a gearbox overhaul.
