It is currently Thu Jan 18, 2018 5:06 am
PostPosted: Tue Nov 25, 2014 12:20 am
I see lots of transmissions come to me with worn out input shafts and bad or broken input shaft bearings.
The reason this happens is the transmission was assembled to the engine without the two hollow guides that keep the transmission
aligned properly to the engine. These guide are a must have if you want your transmission to stay alive. So I have made some and will be selling them in pairs. 1.0L and 1.3L are in similar locations. If you need to make your own, use 0.500" OD steel tubing with a side wall of no thicker then 0.050" with a length of 0.700". I would make two of them. Using only one guide will still give you problems.
PM me if you need some guides.
2693 where the hollow guides should be in the transmission bell housing.
2701 Where the hollow dowl guilds should be on the engine. I was in a hurry. sorry for the fuzzy picture.
Fainya
cron
